- From: Pierre-Evariste Dagand <pierre-evariste.dagand AT ens-cachan.org>
- To: coq-club AT inria.fr
- Subject: [Coq-Club] Fwd: Free monads and strict positivity
- Date: Wed, 8 Oct 2014 11:40:46 +0200
[Resending from the right address. Apologies to the Coq-club
moderator/bouncer.]
> Where I am having difficulties now is figuring out how to use signatures.
> For
> example:
> Definition FH' : (State → Type) → State → Type :=
> ((FilePath ::= Closed) :>>: (fun _ => State)) (* fOpen *)
> :+: ((unit ::= Open) :>>: (option nat ::= Open)) (* fGetC *)
> :+: ((unit ::= Open) :>>: (unit ::= Closed)). (* fClose *)
> Is the Signature over State, or would it be over HF' in this example? Or is
> it something else altogether?
Third option :-)
As I said, everywhere you've been manipulating endofunctors on State
-> Type, you need to define the equivalent operators over signatures.
This includes ":>>:" and ":+:":
1) given a pre-condition P : State -> type and a post-condition Q :
State -> Type, you need to define a signature that will *interpret* to
something (extensionally) equal to your operator ":>>:". That's how
you are going to define operations individually.
2) given two signatures S and S', you need to define a signature that
combines them, ie. that *interprets* to something (extensionally)
equal to your operator ":+:". That's how you are going to aggregate
operations together.
Having defined these combinators, you'll be able to write the same
definition for FH' but, this time, it will build a signature of State.
You can then use that signature to construct the free monad.
Concerning your definition:
> Definition FH : Signature State :=
> {| Operations := fun st : State => State -> Type (* WRONG *)
> ; Arities := fun (st : State) ops => FH' ops st (* WRONG? *)
> ; Sorts := fun (st : State) ops ars => st |}. (* WRONG *)
that's absolutely wrong. You'll realize why after defining the
signature of ":>>:".
Pierre-Evariste
- [Coq-Club] Free monads and strict positivity, John Wiegley, 10/06/2014
- Re: [Coq-Club] Free monads and strict positivity, Pierre-Evariste Dagand, 10/06/2014
- Re: [Coq-Club] Free monads and strict positivity, John Wiegley, 10/08/2014
- Re: [Coq-Club] Free monads and strict positivity, Pierre-Evariste Dagand, 10/08/2014
- [Coq-Club] Fwd: Free monads and strict positivity, Pierre-Evariste Dagand, 10/08/2014
- Re: [Coq-Club] Free monads and strict positivity, Daniel Schepler, 10/07/2014
- Re: [Coq-Club] Free monads and strict positivity, Casteran Pierre, 10/07/2014
