- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Why no unfolding on left in match?
- Date: Wed, 8 Oct 2014 17:04:13 -0400
Yes. I just want some syntactic support to make this lighter weight. (Maybe
it can be done with clever notation now?). Bonus points if your solution
supports nested patterns.
The classic example is wanting to match a string based on regexps.
-Greg
> On Oct 8, 2014, at 3:46 PM, Jonathan
> <jonikelee AT gmail.com>
> wrote:
>> On 10/08/2014 03:14 PM, Greg Morrisett wrote:
>> This is an instance of a more general problem with datatypes/inductive
>> definitions that arises in the ML/Haskell/Coq/etc. community: pattern
>> matching does not promote abstraction.
>> I’ve always wanted to have more control over this in the form of
>> an abstract pattern declaration (with attendant proofs that the
>> patterns are exhaustive and non-overlapping.)
>> -Greg
> Aren't you just requesting the common "dependent view" idiom? Define a new
> inductive type with constructors that are the patterns you want, then
> define a total function mapping the original type(s) to the view type.
> Think of the classic isEven/isOdd example.
> -- Jonathan
- [Coq-Club] Why no unfolding on left in match?, Kevin Sullivan, 10/08/2014
- Re: [Coq-Club] Why no unfolding on left in match?, Adam Chlipala, 10/08/2014
- Re: [Coq-Club] Why no unfolding on left in match?, Kevin Sullivan, 10/08/2014
- Re: [Coq-Club] Why no unfolding on left in match?, Greg Morrisett, 10/08/2014
- Re: [Coq-Club] Why no unfolding on left in match?, Jonathan, 10/08/2014
- Re: [Coq-Club] Why no unfolding on left in match?, Enrico Tassi, 10/08/2014
- Re: [Coq-Club] Why no unfolding on left in match?, Abhishek Anand, 10/08/2014
