- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] backtracking issues in extern hints
- Date: Tue, 14 Oct 2014 11:42:21 -0400
Is the following supposed to work?
Inductive foo : nat -> Prop :=
| Foo1 : foo 1
| Foo2 : foo 2.
Hint Extern 5 (foo _) => econstructor.
Inductive bar : Type :=
| Bar{n}(f : foo n)(neq : n = 2) : bar.
Hint Constructors bar.
Goal bar.
solve [eauto]. (*needs to backtrack with evar n to try Foo1 then Foo2*)
Qed.
If the extern hint for foo is replaced with "Hint Constructors foo", then it works (for both n=1 and n=2). But I can't replicate that backtracking behavior with an extern hint - which I sometimes need to get finer control over which constructors are used when and at what cost. Note that it also doesn't work with "Hint Extern 5 (foo _) => (econstructor 1 + econstructor 2), but of course does if the two constructors are reversed (since no backtracking is needed then).
The behavior is the same with "typeclasses eauto with core" vs. "solve [eauto]".
However, "solve [econstructor;[econstructor|eauto]]." solves the bar goal - so the backtracking I'm looking for appears to be working sometimes, but not in extern hints.
Is this a bug, a feature, or not fully developed?
I'm working in a recent trunk (ea57f83dfdb3738e933b33f0a919e06a80bad151, pulled Oct 7).
-- Jonathan
- [Coq-Club] backtracking issues in extern hints, Jonathan, 10/14/2014
- Re: [Coq-Club] backtracking issues in extern hints, Pierre-Marie Pédrot, 10/14/2014
- Re: [Coq-Club] backtracking issues in extern hints, Jonathan, 10/14/2014
- Re: [Coq-Club] backtracking issues in extern hints, Arnaud Spiwack, 10/15/2014
