- To: coq-club <coq-club AT inria.fr>
- Subject: [Coq-Club] Adding Top-Level Declaration Syntax
- Date: Mon, 20 Oct 2014 10:38:37 -0700
Hi,
I am interested in adding my own top-level declaration forms, like “Program
Definition” and “Functional Scheme”, which generate obligations and/or add
definitions to the current section / module. Is there any documentation on
how to do this? Presumably, I could define such a thing as a separate ML
module that could be loaded into Coq, without modifying the Coq source
itself. I have been looking a little at the plugins/ directory for some
examples, but it would be much easier to wade through that code with a little
bit of guidance.
Thanks,
-Eddy
- [Coq-Club] Adding Top-Level Declaration Syntax, Eddy Westbrook, 10/20/2014
- Re: [Coq-Club] Adding Top-Level Declaration Syntax, Pierre-Marie Pédrot, 10/20/2014
- Re: [Coq-Club] Adding Top-Level Declaration Syntax, Eddy Westbrook, 10/21/2014
- Re: [Coq-Club] Adding Top-Level Declaration Syntax, Gregory Malecha, 10/21/2014
- Re: [Coq-Club] Adding Top-Level Declaration Syntax, Eddy Westbrook, 10/22/2014
