- To: Vladimir Voevodsky <vladimir AT ias.edu>
- Cc: Coq Club <coq-club AT inria.fr>, homotopytypetheory <homotopytypetheory AT googlegroups.com>
- Subject: Re: [Coq-Club] eliminators
- Date: Thu, 23 Oct 2014 12:31:50 +0200
If you care about modularity, i.e., not let people pattern match on a value of your type, you can always use the module system to hide the definition of your type:
Module Type MyEmptySetSig.
Parameter t : Type.
Parameter case : forall {P : t -> Type} (e : t), P e.
End MyEmptySetSig.
Module MyEmptySet : MyEmptySetSig.
Definition t := Empty_set.
Definition case := Empty_set_rect.
End MyEmptySet.
Definition test_myemptyset { X : Type } : MyEmptySet.t -> X .
Proof . intros H . apply (MyEmptySet.case H). Defined.
Print test_myemptyset.
Parameter t : Type.
End MyEmptySetSig.
End MyEmptySet.
On Thu, Oct 23, 2014 at 12:17 PM, Vladimir Voevodsky <vladimir AT ias.edu> wrote:
Ahhh… It must have changed since that time. I tried it with “induction” and itworks. Thank you very much!V.On Oct 23, 2014, at 11:00 AM, Beta Ziliani <beta AT mpi-sws.org> wrote:BetaPerhaps I'm not understanding fully your question, but match *is* the eliminator. Empty_set_rect is the inductive principle, build in terms of that eliminator. If you want to use the later, you should use [induction] instead of destruct. [destruct] is not unfolding anything, it is just a tactic for building a [match] interactively.Best,On Thu, Oct 23, 2014 at 11:34 AM, Vladimir Voevodsky <vladimir AT ias.edu> wrote:Hello,
is there a way to make Coq print proof terms using eliminators when these proof terms are constructed using
eliminators?
For example “destruct” uses the eliminators but the proof terms constructed with destruct are printed in terms of “match” even
when I request the corresponding eliminator to be opaque. An example code is below.
This makes it very difficult for me to teach Coq to mathematicians. I can explain eliminators to them but I do not know how to explain
match to them and I am not even sure that a semantically adequate theory of dependent “match” exists. In any event even if it does
exist it is still not right that when I request something to be opaque Coq unfolds it without asking.
Opaque Empty_set_rect.
Opaque Empty_set_rec.
Opaque Empty_set_ind.
Definition test { X : UU } : Empty_set -> X .
Proof . intros X H . destruct H . Defined.
Print test.
Definition test' { X : UU } : Empty_set -> X := fun H => Empty_set_rect ( fun x => X ) H .
Print test' .
Vladimir.
- [Coq-Club] eliminators, Vladimir Voevodsky, 10/23/2014
- Re: [Coq-Club] eliminators, Beta Ziliani, 10/23/2014
- Re: [Coq-Club] eliminators, Vladimir Voevodsky, 10/23/2014
