- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Proving equalities for records with Prop component
- Date: Thu, 23 Oct 2014 21:27:50 +0400
Frederic,
Sorry, bad example. Is there a way for not-decidable equalities?
Can such problem be solved at all? I'm not sure about it.
Sincerely,
Kirill Taran
Kirill Taran
On Thu, Oct 23, 2014 at 7:56 PM, Frédéric Loulergue <frederic.loulergue AT univ-orleans.fr> wrote:
Hi,
For decidable types, there is uniqueness of identity proofs, i.e. only one proof of x = x.
The Coq library provides this theorem in a module in Coq.Logic.Eqdep_dec.
Require Import Arith.
Require Import Coq.Logic.Eqdep_dec.
Record R := { number : nat; proof : exists n, n + number = 100 }.
Module NatDec.
Definition U := nat.
Lemma eq_dec : forall x y:U, {x = y} + {x <> y}.
decide equality.
Qed.
End NatDec.
Module Dec := DecidableEqDep NatDec.
Lemma r_eq (x y : R) : number x = number y -> x = y.
Proof.
intro H.
destruct x as [x Hx]; destruct y as [y Hy]; simpl in H; subst.
destruct Hx as [n H]; destruct Hy as [n' H'].
assert(n = n') by
(rewrite <-H' in H; rewrite <- NPeano.Nat.add_cancel_r; eauto).
subst.
assert(H = H') as HH' by apply Dec.UIP.
now rewrite HH'.
Qed.
Best,
Frederic
Le 23/10/2014 17:27, Kirill Taran a écrit :
Hello,
I have such problem:
Admitted.
Is it possible to solve it and how?
Sincerely,
Kirill Taran
- [Coq-Club] Proving equalities for records with Prop component, Kirill Taran, 10/23/2014
- Re: [Coq-Club] Proving equalities for records with Prop component, Frédéric Loulergue, 10/23/2014
- Re: [Coq-Club] Proving equalities for records with Prop component, Kirill Taran, 10/23/2014
- Re: [Coq-Club] Proving equalities for records with Prop component, Eddy Westbrook, 10/23/2014
