- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] type conversion
- Date: Mon, 27 Oct 2014 15:44:39 +0100
Thanks, Julien. It works with Set in place of Type in:
Theorem subst: forall(T U:Set), T = U -> T -> U.
Proof.
intros. rewrite <-H. apply X.
Defined.
But how can I achieve the proof of:
Require Import Arith.
Lemma test_subst: forall H : nat = nat,
subst nat nat H 5 = 5.
Thank you,
Regards,
Jean-François
Le 27/10/2014 13:05,
julien.forest AT ensiie.fr
a écrit :
On Sun, 26 Oct 2014 16:29:18 +0100
Jean-François Dufourd
<jfd AT unistra.fr>
wrote:
Theorem subst: forall(T U:Type), T = U -> T -> U.
Proof.
Defined.
Hi,
your hypothesis H has exact type @eq Set nat nat while the subst Lemma
waits for an hypothesis (@eq Type nat nat). The conversion between Set
and Type does not seems to be automatic here.
Best regards,
Julien
- Re: [Coq-Club] type conversion, julien . forest, 10/27/2014
- Re: [Coq-Club] type conversion, Jean-François Dufourd, 10/27/2014
