- From: Pierre Courtieu <pierre.courtieu AT gmail.com>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Encoding Tactic Sequences in Ltac
- Date: Mon, 27 Oct 2014 23:32:27 +0100
Hi,
You first need to write your three "tactics" into three single tactics
(the period ends a tactic, so "intros. rewrite mult_n_O. trivial." is
actually three tactics) because tacticals take unique tactics as
arguments.
Most of the time this is easy using the ";" tactical. sometimes you
may also need the [ | ] tactical to apply different tactics to
different subgoals. For example: tactic3 should probably be written
"induction n; [intros; simpl; trivial | simpl; trivial].
Once you rewrote the three "tactics" into three single ones you may
combine them in several ways. Eric suggested one, you can also try
solve [tactic1 | tactic2 | tactit3]
or:
try now tactic1 ; try now tactic2 ; try now tactic3
etc.
Hope this helps,
Pierre
2014-10-27 21:34 GMT+01:00 Eric Mullen
<emullen AT cs.washington.edu>:
> Is what you want similar to:
> try solve [tactic1]; try solve [tactic2]....
> On Oct 27, 2014 1:26 PM, "Gransden, Thomas"
> <tg75 AT student.le.ac.uk>
> wrote:
>> Hi all,
>> I was just wondering if there was a way of encoding the following scenario
>> in Ltac:
>> Say that we have a few sequences of tactics that we use often in a corpus
>> of proofs - for example lets say the following:
>> t1 - intros. rewrite mult_n_O. trivial.
>> t2 - intros. destruct_all bool. reflexivity.
>> t3 - induction n. intros. simpl; trivial. simpl; trivial.
>> Can I create an Ltac tactic that applies t1 OR t2 OR t3?
>> I have had a play around with Ltac but cannot seem to get something like
>> this working, so any help or hints would be much appreciated.
>> Thanks
>> Tom
- [Coq-Club] Encoding Tactic Sequences in Ltac, Gransden, Thomas, 10/27/2014
- Re: [Coq-Club] Encoding Tactic Sequences in Ltac, Eric Mullen, 10/27/2014
- Re: [Coq-Club] Encoding Tactic Sequences in Ltac, Pierre Courtieu, 10/27/2014
