- From: mukesh tiwari <mukeshtiwari.iiitm AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Software foundation ( Palindrome List )
- Date: Fri, 31 Oct 2014 17:19:10 +0530
Hi Jakob,
Thank you! On Fri, Oct 31, 2014 at 5:12 PM, Jakob Vidmar <jakob AT vidmar.be> wrote:
Hi Mukesh,Hint: Is [a] not a palindrome ?Cheers,JakobOn 31 Oct 2014, at 11:37, mukesh tiwari <mukeshtiwari.iiitm AT gmail.com> wrote:Hello Everyone,I tried to prove following theorem
I am trying to solve this problem from Software Foundations[1].
Exercise: 4 stars (palindromes)
A palindrome is a sequence that reads the same backwards as forwards.
Define an inductive proposition pal on list X that captures what it means to be a palindrome. (Hint: You'll need three cases. Your definition should be based on the structure of the list; just having a single constructor
c : ∀l, l = rev l → pal l
may seem obvious, but will not work very well.)
Prove that
∀l, pal (l ++ rev l).
Prove that
∀l, pal l → l = rev l.
Inductive data type for palindrome.
Inductive pal { X : Type } : list X -> Prop :=
| emptyC : pal nil
| consC : forall ( a : X ) ( l : list X ) , pal l -> pal ( a :: l ++ [a]).
The hint says that we need three case which I am not able to follow. I came up with following reasoning. Empty list is palindrome ( emptyC constructor ).
If you give me any element a of type X and a palindrome list l of type list X, I can construct another palindrome list ( a :: l ++ [a] ) ( consC constructor ).
Theorem reverseonlist : forall { X : Type } ( l : list X ), pal ( l ++ rev l).
Proof.
intros X l. induction l as [ | v' l'].
Case "l = nil".
simpl. apply emptyC.
Case "l = Cons v' l'".
simpl.
(* This is my goal after apply the simplification.
Case := "l = Cons v' l'" : String.string
X : Type
v' : X
l' : list X
IHl' : pal (l' ++ rev l')
pal (v' :: l' ++ snoc (rev l') v')
rewrite -> snoc_list.(* After this goal changes to
X : Type
v' : X
l' : list X
pal (v' :: l' ++ rev l' ++ [v'])
*)apply consC with ( a := v' ) ( l := l' ++ rev l' ).and getting this error
Toplevel input, characters 6-50:
Error: Impossible to unify "pal (v' :: (l' ++ rev l') ++ [v'])" with
"pal (v' :: l' ++ rev l' ++ [v'])".
snoc_list: forall (X : Type) (v : X) (s : list X), snoc s v = s ++ [v].I have little bit of Coq experience so it may be related to associativity of ++. Could some one please tell me how to solve this problem. ( A hint would be great ).-Mukesh Tiwari
- [Coq-Club] Software foundation ( Palindrome List ), mukesh tiwari, 10/31/2014
- Re: [Coq-Club] Software foundation ( Palindrome List ), Jakob Vidmar, 10/31/2014
- Re: [Coq-Club] Software foundation ( Palindrome List ), mukesh tiwari, 10/31/2014
- Re: [Coq-Club] Software foundation ( Palindrome List ), Laurent Théry, 10/31/2014
