coq-club - Re: [Coq-Club] Splitting evars?
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Splitting evars?
  • Date: Sun, 09 Nov 2014 18:48:11 -0500
On 11/09/2014 06:28 PM, Jason Gross wrote:
Hi,
Is there a way to "split" evars in Coq? I'm trying to get rewriting by
shape to work (since it's my opinion that hypotheses should not have
names). I have a single rewrite working:
Ltac tac_shape shape tac :=
match goal with
| [ H : ?shape' |- _ ] => unify shape' shape; tac H
end.
Tactic Notation "shape" "rewrite" open_constr(shape) := tac_shape shape
ltac:(fun H => rewrite H).
Goal forall a b c d : Set, a = b -> b = c -> a = c.
intros.
repeat shape rewrite (_ = _); reflexivity.
But if I try to build an equivalent of [rewrite !H], and bring the [repeat]
inside the tactic notation, then I end up with something that (predictably)
doesn't work:
match goal with
end.
Tactic Notation "shape" "rewrite" "?" open_constr(shape) := repeat
tac_shape shape ltac:(fun H => rewrite !H).
Tactic Notation "shape" "rewrite" "!" open_constr(shape) := progress shape
rewrite ? shape.
intros.
Undo.
shape rewrite ! (_ = _). reflexivity.
So my question is: is there a way to split the evars, so I can bring the
[repeat] inside the [Tactic Notation] while keeping the pattern outside of
it?
Thanks,
Jason
The trick I found the other day seems to handle this as well:
let e := fresh in
refine (let e := shape in _);
shelve_unifiable;
let v := eval red in e in clear e;
match goal with H : ?C |- _ =>
unify v C; tac H
end.
Tactic Notation "shape" "rewrite" uconstr(shape) := tac_shape shape
Tactic Notation "shape" "rewrite" "?" uconstr(shape) := repeat
Tactic Notation "shape" "rewrite" "!" uconstr(shape) := progress shape
rewrite ? shape.
intros.
Undo.
Qed.
Note the use of uconstr instead of open_constr. By the way, why isn't open_constr documented?
-- Jonathan
