- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] How to access the elements of a record in coq
- Date: Fri, 14 Nov 2014 10:20:54 +0100
For information, records are just inductives.
Thus your type is in fact:
Inductive ToyModel:=
X : forall
(universe:Set)
(aNiceProperty:universe->Prop)
(color:universe->nat),
ToyModel.
Where "X" is automatically generated, along with projections as said by Eddy.
I think you can find out this generated name with "Print ToyModel."
To extract "universe" from "tm" you can do the following:
- match tm with X (*to be replaced by its real name*) uni _ _ => uni end
- let (uni, _, _) := tm in uni (* syntactic shorthand for single constructor types *)
- universe tm
- tm.(universe) (* access field for records [in fact a notation for "universe tm"] *)
X : forall
(universe:Set)
ToyModel.
- universe tm
2014-11-14 1:06 GMT+01:00 Eddy Westbrook <westbrook AT kestrel.edu>:
The fields of a record become projection functions. So, in your definition, universe has type ToyModel -> Set, i.e., when applied to a ToyModel, universe projects out and returns the universe component of it. Similarly with the other fields you have defined.From there, you should hopefully be able to write your definition. :)-EOn Nov 13, 2014, at 3:43 PM, Namio Namelander <verifying AT ndtvmail.com> wrote:Suppose I have a record
Record ToyModel:={
universe:Set;
aNiceProperty:universe->Prop;
color:universe->nat
I would like to define a notion of compatibility for
elements of type ToyModel.
Definition Compatible(T1 T2: ToyModel):=
if there is an element of T1.universe with color a then there
exists an element of T2.universe with color a.
How can I write this in coq? The problem is that I don't know
how to access the elements inside a record.
.../Sedrikov\...
- [Coq-Club] How to access the elements of a record in coq, Namio Namelander, 11/14/2014
- Re: [Coq-Club] How to access the elements of a record in coq, Eddy Westbrook, 11/14/2014
- Re: [Coq-Club] How to access the elements of a record in coq, Cedric Auger, 11/14/2014
