- From: CHAUVIN Barnabe <barnabe.chauvin AT gmail.com>
- To: coq-club AT inria.fr
- Subject: [Coq-Club] Is there a type representing the reals set (R) ?
- Date: Mon, 17 Nov 2014 23:21:26 +0100
I am currently exploring the standard library, and I feel like the different theories (Like for example Reals, Sets, Logic ...) are not really working together ..
I was actually looking for a type of the reals set (Exactly like the inductive type Integers), to be able to use the Sets theories (Ensembles.v ... and especially the order theorems/lemmas).
In Rdefinitions, I found the is_upper_bound definition, which represent the R set with the type R->Prop. It would be more understandable if it would be "Ensemble R", isn't it ? (This is the reason why I said I feel like the theories are not working together ..)
Nevertheless, I didn't find such a defintion (the R set). Is-it my mistake, or it is impossible to define such a type, because of the definition of the reals in coq (with axioms) ?
Or maybe I am free to use almost the same definition as Integers, i.e. "Inductive Reals : Ensemble R := Reals_defn : forall x:nat, In R Reals x." and then define a partial order on this set ("PO R") ?
Kind regards,
Barnabé Chauvin
- [Coq-Club] Is there a type representing the reals set (R) ?, CHAUVIN Barnabe, 11/17/2014
- Re: [Coq-Club] Is there a type representing the reals set (R) ?, John Wiegley, 11/17/2014
- Re: [Coq-Club] Is there a type representing the reals set (R) ?, Daniel Schepler, 11/17/2014
- Re: [Coq-Club] Is there a type representing the reals set (R) ?, CHAUVIN Barnabe, 11/18/2014
- Re: [Coq-Club] Is there a type representing the reals set (R) ?, Daniel Schepler, 11/18/2014
