- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] minimizing number of lines in a goal
- Date: Wed, 19 Nov 2014 19:49:39 -0500
With the new (trunk) feature that shows consecutive hypotheses with the same type on a single goal line, is there a way to write a tactic that minimizes the number of lines in a goal without any other impact on the goal? My first few attempts either didn't do the job completely in all cases, or loop.
Not that there's any big need for this, other than as a way to entertain one's obsessive-compulsive tendencies ;)
For instance:
Ltac minlines :=
match reverse goal with H:?T |- _ => repeat match goal with H':T |- _ =>
match H' with H => fail 2 | _ => move H' after H end end end.
Goal forall (i : nat)(a : bool)(j : nat)(b : bool)(k : nat)(c : bool), False.
intros. (*6 lines of hyps*)
minlines. (*now just 2 lines of hyps*)
Abort.
(*But minlines as defined above doesn't work in all cases:*)
Goal forall (i : nat)(a : bool)(j : nat)(l : list nat)(b : bool)(k : nat)(c : bool), False.
intros. (*7 lines of hyps*)
minlines. (*4 lines, when just 3 are possible*)
Abort.
-- Jonathan
- [Coq-Club] minimizing number of lines in a goal, Jonathan, 11/20/2014
