- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Theorems about functions that produce option
- Date: Sun, 23 Nov 2014 11:55:04 -0300
Hi Artur,
Thanks for your help. I have tried your suggestions and they indeed work. However, when I try to prove the theorem looks like I need to know what is the value of m.
Here is the first version of the theorem and its proof:
Theorem dummy_theorem1 : exists n : nat, match dummy_function n with| None => False| Some _ => Trueend.Proof.exists 1.reflexivity.Qed.
Here is the second version:
Theorem dummy_theorem2 : exists n m : nat, dummy_function n = Some m.Proof.exists 1.reflexivity.Qed.
But Coq says
"Tactic failure: The relation ex is not a declared reflexive relation. Maybe you need to require the Setoid library.Compilation output:"
, probably because I did not specify the value of m.
Coq accepts the proof below. But this requires that I know the specific value that is inside the option produce by (dummy_function 1).
Your second suggestion (exists n, dummy_function n <> None) is really nice but my problem is a little more complicated than dummy_function because my (real) theorem says something about the value that is inside the option produced by a function.Theorem dummy_theorem2 : exists n m : nat, dummy_function n = Some m.Proof.exists 1.exists 1.reflexivity.Qed.
I tried to formulate my doubts using dummy_function as an example, but I simplified the problem too much.
Thanks for your help!
Saulo
On Sun, Nov 23, 2014 at 11:31 AM, Arthur Azevedo de Amorim <arthur.aa AT gmail.com> wrote:
The problem with your first attempt is just that m was not bound
anywhere in your statement. You can fix it by saying something like
exists n m, dummy_function n = Some m
or
Usually, the first form will be more convenient to use.
Best
2014-11-23 8:50 GMT-05:00 Saulo Araujo <saulo2 AT gmail.com>:
--> Hi,
> I am trying to write a theorem that says that a function produces Some when
> some conditions are met.
> For example, suppose the dummy_function is defined like below
> Definition dummy_function (n : nat) : option nat :=
> match n with
> | 0 => None
> | _ => Some 1
> end.
> When I try
> Theorem dummy_theorem1 : exists n : nat, dummy_function n = Some m.
> Coq says
> "The reference m was not found in the current environment."
> So I tried
> Theorem dummy_theorem1 : exists n : nat, dummy_function n = Some _.
> In this case, Coq says
> "Error: Cannot infer this placeholder."
> After some attempts, I ended up with the following version
> | None => False
> | Some _ => True
> end.
> I'd like to know if there is a better way to state a theorem like this.
> Thanks,
> Saulo Medeiros de Araujo
- [Coq-Club] Theorems about functions that produce option, Saulo Araujo, 11/23/2014
- Re: [Coq-Club] Theorems about functions that produce option, Arthur Azevedo de Amorim, 11/23/2014
- Re: [Coq-Club] Theorems about functions that produce option, Saulo Araujo, 11/23/2014
