Re: [Coq-Club] (user experience report) "Proof assistants as routine tools", Neil Strickland
- From: Frédéric Blanqui <frederic.blanqui AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] (user experience report) "Proof assistants as routine tools", Neil Strickland
- Date: Tue, 25 Nov 2014 17:47:51 +0100
Hello. Here is a relatively short (150 lines) classical proof of the infinity of prime numbers. Best regards, Frédéric.
Le 25/11/2014 10:13, Gabriel Scherer a écrit :
Dear coq-club,
You may be interested in the slides of a talk given by Neil Stickland
at the Homotopy Type Theory Workshop, a few weeks ago in Oxford. It
reads as an experience report of something relatively experienced with
proof assistants trying to prove a basic mathematic fact (there are
infinitely many primes) and listing the hurdles (in tooling,
documentation, web search, etc.) along the way.
http://www.qmac.ox.ac.uk/events/Talk%20slides/Neil%20Strickland.pdf
You will probably find little surprising there, but I think that
seeing those pain-points in the context of a concrete use-case --
instead of problems in the abstract -- helps.
(** Euclid's proof that prime numbers are infinite. Frédéric Blanqui, INRIA, 25 November 2014. *) Set Implicit Arguments. (** Lemmas on multiplication. *) Require Import Arith Omega. Lemma mult_gt_0 a b : a * b > 0 <-> a > 0 /\ b > 0. Proof. (* We proceed by case on a and b. *) destruct a. omega. destruct b. omega. split. omega. intros _. simpl. (*omega does not work here!*) apply gt_Sn_O. Qed. Lemma le_mult_r a b : b > 0 -> a <= a * b. Proof. intros hb. rewrite <- (mult_1_r a) at 1. apply mult_le_compat_l. omega. Qed. (** Divisibility. *) Definition divide a b := exists q, b = a * q. Infix "\" := divide (at level 70). Lemma divide_le a b : b > 0 -> a \ b -> a <= b. Proof. intros b_gt_0 [q ha]. subst. apply le_mult_r. rewrite mult_gt_0 in b_gt_0. tauto. Qed. Lemma divide_mult_l a b c : a \ b -> a \ c * b. Proof. intros [q ha]. subst. exists (q*c). ring. Qed. Lemma divide_minus a b c : a \ b -> a \ c -> a \ b-c. Proof. intros [p hb] [q hc]. subst. exists (p-q). (* omega does not work here! *) rewrite <- mult_minus_distr_l. reflexivity. Qed. Lemma divide_trans a b c : a \ b -> b \ c -> a \ c. Proof. intros [q h] [r g]. exists (q * r). subst. ring. Qed. (** Product of a list of natural numbers. *) Require Import List. Fixpoint prod l := match l with | nil => 1 | a :: l' => a * prod l' end. Lemma prod_gt_0 : forall l, ~In 0 l <-> prod l > 0. Proof. induction l; simpl. omega. rewrite mult_gt_0. intuition. Qed. Lemma in_prod {a} : forall {l}, ~In 0 l -> In a l -> a <= prod l. Proof. (* We proceed by induction on l. *) induction l as [|b l hl]; simpl. omega. intros hb [ha|ha]. subst. apply le_mult_r. apply prod_gt_0. tauto. rewrite <- (mult_1_l a) at 1. apply mult_le_compat. omega. tauto. Qed. Lemma divide_prod {a} : forall {l}, In a l -> a \ prod l. Proof. (* We proceed by induction on l. *) induction l as [|b l hl]; simpl. tauto. intros [ha|ha]. subst. exists (prod l). reflexivity. apply divide_mult_l. tauto. Qed. (** Prime numbers. *) Definition prime b := b >= 2 /\ forall a, divide a b -> a = 1 \/ a = b. Lemma zero_isnt_prime : ~prime 0. Proof. unfold prime. omega. Qed. Theorem fundamental_theorem_of_arithmetic a : a >= 2 -> exists p, prime p /\ p \ a. Proof. (* We proceed by well-founded induction on a. *) pattern a; apply lt_wf_ind; clear a; intros a IHa a_ge_2. Require Import Classical. destruct (classic (prime a)) as [a_is_prime|a_isnt_prime]. (* If a is prime, then we can take p=a. *) exists a. intuition. exists 1. ring. (* If a is not prime, then there is some b between 2 and a-1 that divides a. *) apply not_and_or in a_isnt_prime. intuition. apply not_all_ex_not in H. destruct H as [b hb]. apply imply_to_and in hb. destruct hb as [b_div_a hb]. apply not_or_and in hb. assert (b_lt_a : b < a). apply divide_le in b_div_a. omega. omega. assert (b_ge_2 : b >= 2). destruct b_div_a as [q ha]. destruct (eq_nat_dec b 0). 2: omega. subst. omega. (* By induction hypothesis on b, there is some prime p that divides b, and thus a by transitivity. *) destruct (IHa _ b_lt_a b_ge_2) as [p [p_prime p_div_b]]. exists p. intuition. apply divide_trans with b; assumption. Qed. Theorem primes_are_infinite : ~ (exists l, forall a, prime a <-> In a l). Proof. intros [l all_primes_in_l]. set (n := S (prod l)). (* We prove that n is prime. *) assert (n_is_prime : prime n). split. (* n >= 2 *) apply le_n_S. apply lt_le_S. apply prod_gt_0. rewrite <- all_primes_in_l. apply zero_isnt_prime. (* We now prove that assuming that there is a divider a of n that is different from 1 and n leads to a contradiction. *) intros a a_div_n. destruct (eq_nat_dec a 1). tauto. right. destruct (eq_nat_dec a n). assumption. apply False_rec. (* We prove that a is >= 2. *) assert (a_ge_2 : a >= 2). destruct a_div_n as [q hn]. destruct (eq_nat_dec a 0). subst. rewrite mult_0_l in hn. omega. omega. (* Hence, a has a prime divider p. *) destruct (fundamental_theorem_of_arithmetic a_ge_2) as [p [p1 p2]]. (* By transitivity, p divides n. *) generalize (divide_trans p2 a_div_n); intro p_div_n. (* Since all primes are in l, p is in l and p divides prod l. *) assert (p_in_l : In p l). rewrite <- all_primes_in_l. assumption. apply divide_prod in p_in_l. (* Thus p divides n-prod l=1. *) generalize (divide_minus p_div_n p_in_l). unfold n. rewrite <- minus_Sn_m, minus_diag. 2: reflexivity. (* Therefore p=1 but 1 is not prime. Hence, n is prime. *) intros [q hp]. symmetry in hp. apply mult_is_one in hp. destruct hp. subst. destruct p1. omega. (* We now prove that n is not in l. *) rewrite all_primes_in_l in n_is_prime. assert (zero_notin_l : ~In 0 l). rewrite <- all_primes_in_l. unfold prime. omega. generalize (in_prod zero_notin_l n_is_prime). unfold n. omega. Qed.
- [Coq-Club] (user experience report) "Proof assistants as routine tools", Neil Strickland, Gabriel Scherer, 11/25/2014
- Re: [Coq-Club] (user experience report) "Proof assistants as routine tools", Neil Strickland, Frédéric Blanqui, 11/25/2014
- Re: [Coq-Club] (user experience report) "Proof assistants as routine tools", Neil Strickland, Carst Tankink, 11/26/2014
- Re: [Coq-Club] (user experience report) "Proof assistants as routine tools", Neil Strickland, Enrico Tassi, 11/26/2014
- Re: [Coq-Club] (user experience report) "Proof assistants as routine tools", Neil Strickland, Ilmārs Cīrulis, 11/30/2014
- Re: [Coq-Club] (user experience report) "Proof assistants as routine tools", Neil Strickland, Cedric Auger, 11/30/2014
- Re: [Coq-Club] (user experience report) "Proof assistants as routine tools", Neil Strickland, Cyril Cohen, 11/26/2014
- Re: [Coq-Club] (user experience report) "Proof assistants as routine tools", Neil Strickland, Pierre Courtieu, 11/26/2014
