- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Coq-graphs
- Date: Wed, 26 Nov 2014 00:39:09 +0000
There is an undocumented option (-dumpgraphbox)grouping modules into (nested)
clusters based on the directories they live in. We used to draw boxes around
these clusters (hence the name) but I guess it might be possible to get dot
to vary the colours instead?
If it's not possible, patching the printing function to do that should be
quite easy anyways because all the information is already available (the modules
are listed in a rosetree where the nodes carry directory names and the leaves
are the files' names): https://github.com/coq/coq/blob/trunk/tools/coqdep.ml#L382
On 25/11/14 20:05, Jason Gross wrote:
Neat! However, dpdgraph is for dependencies between theorems and definitions, not just files/modules.
Is there any way to get -dumpgraph to color the modules by which folder they live in?
On Tue Nov 25 2014 at 5:34:37 AM gallais <guillaume.allais AT strath.ac.uk <mailto:guillaume.allais AT strath.ac.uk>> wrote:
Hi,
If that is a tool printing a dependency graph between the various
modules
of a project then there is no need to install anything: Pierre
Marie Pédrot
ported the patch we used to use internally in the coqtail project to
upstream
coqdep:
https://github.com/coq/coq/commit/093529c6d4f8eba7370c30b97d8d648340039374
Cheers,
On 24/11/14 09:49, Frédéric Blanqui wrote:
> Hi! Perhaps http://www-verimag.imag.fr/~monin/Soft/Dependot/
<http://www-verimag.imag.fr/%7Emonin/Soft/Dependot/> may be of
> interest too. Best regards, Frédéric.
> Le 24/11/2014 06:46, Eric Mullen a écrit :
>> Thanks! I'll look into dpdgraph. Much appreciated!
>> Eric
>> On Sun Nov 23 2014 at 9:44:02 PM Jason Gross
<jasongross9 AT gmail.com
<mailto:jasongross9 AT gmail.com>
<mailto:jasongross9 AT gmail.com>>>
wrote:
>> The links on that site also talk about Coq 6.3 being the latest
>> version of Coq. When I asked about this a while ago I was
>> pointed at dpdgraph. I don't recall where the original sources
>> are (a google search might give them), there's a variant that
>> works with a recent trunk at
>> https://github.com/HoTT/HoTT/tree/master/etc/dpdgraph-0.4alpha,
>> and if you look through the history, the first version added
>> might work with 8.4.
>> -Jason
>> On Nov 24, 2014 12:16 AM, "Eric Mullen"
<emullen AT cs.washington.edu
<mailto:emullen AT cs.washington.edu>
<mailto:emullen AT cs.washington.edu>>>
wrote:
>> I'm interested in building a tool to visualize
theorem/lemma
>> dependencies and proof status (admitted or proven) in order
>> to help with project management of large verification
>> projects. I found the website for this tool
>> (http://www-sop.inria.fr/lemme/coq-graphs/) but both of the
>> download links give me back ERR_FTP_FAILED. Is there
another
>> way I could get this tool, or is there a proper person
for me
>> to contact about the links being bad?
>> Thanks!
>> Eric Mullen
>> University of Washington
- [Coq-Club] Coq-graphs, Eric Mullen, 11/24/2014
- Re: [Coq-Club] Coq-graphs, Jason Gross, 11/24/2014
- Re: [Coq-Club] Coq-graphs, Eric Mullen, 11/24/2014
- Re: [Coq-Club] Coq-graphs, Frédéric Blanqui, 11/24/2014
- Re: [Coq-Club] Coq-graphs, gallais, 11/24/2014
- Re: [Coq-Club] Coq-graphs, Jason Gross, 11/25/2014
- Re: [Coq-Club] Coq-graphs, gallais, 11/26/2014
- Re: [Coq-Club] Coq-graphs, Jean-Francois Monin, 11/26/2014
