- To: Thorsten Altenkirch <Thorsten.Altenkirch AT nottingham.ac.uk>
- Cc: agda list <agda AT lists.chalmers.se>, "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] [Agda] Maxime Dene's bug fixed
- Date: Thu, 27 Nov 2014 11:49:14 +0100
* (Since Agda 2.4.2:) Termination checking --without-K restricts
structural descent to arguments ending in data types or `Size`.
Likewise, guardedness is only tracked when result type is data or
record type.
mutual
data WOne : Set where wrap : FOne → WOne
FOne = ⊥ → WOne
noo : (X : Set) → (WOne ≡ X) → X → ⊥
noo .WOne refl (wrap f) = noo FOne iso f
`noo` is rejected since at type `X` the structural descent
`f < wrap f` is discounted --without-K.
data Pandora : Set where
C : ∞ ⊥ → Pandora
loop : (A : Set) → A ≡ Pandora → A
loop .Pandora refl = C (♯ (loop ⊥ foo))
`loop` is rejected since guardedness is not tracked at type `A`
--without-K.
See issues 1023, 1264, 1292.
Regarding the second question, please take a look at our ICFP paper from this year: http://dl.acm.org/authorize?N87775.
Cheers,
Not long ago Maxime Denes reported a problem with Coq which lead to it being incompatible with univalence. Also it meant that there are programs definable by structural recursion which are not derivable using eliminators. This was also applicable to Agda even with the without-K flag turned on. One version of the bug in Agda (by Conor) is below.My question is: is this bug fixed in the current versions of Agda and Coq?Next question: how can we make sure that there are no other issues of this kind?Thorsten{-# OPTIONS --without-K #-}module BadWithoutK wheredata Zero : Set wheredata WOne : Set wherewrap : (Zero -> WOne) -> WOnedata _<->_ (X : Set) : Set -> Set whereRefl : X <-> XpostulatemyIso : WOne <-> (Zero -> WOne)moo : WOne -> Zeronoo : (X : Set) -> (WOne <-> X) -> X -> Zeromoo (wrap f) = noo (Zero -> WOne) myIso fnoo .WOne Refl x = moo xbad : Zerobad = moo (wrap \ ())
This message and any attachment are intended solely for the addressee and may contain confidential information. If you have received this message in error, please send it back to me, and immediately delete it. Please do not use, copy or disclose the information contained in this message or in any attachment. Any views or opinions expressed by the author of this email do not necessarily reflect the views of the University of Nottingham.
This message has been checked for viruses but the contents of an attachment may still contain software viruses which could damage your computer system, you are advised to perform your own checks. Email communications with the University of Nottingham may be monitored as permitted by UK legislation.
_______________________________________________
Agda mailing list
Agda AT lists.chalmers.se
https://lists.chalmers.se/mailman/listinfo/agda
- [Coq-Club] Maxime Dene's bug fixed, Thorsten Altenkirch, 11/27/2014
- Re: [Coq-Club] [Agda] Maxime Dene's bug fixed, Jesper Cockx, 11/27/2014
