coq-club - [Coq-Club] recursive definition
  • From: "psperatto AT adinet.com.uy" <psperatto AT adinet.com.uy>
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] recursive definition
  • Date: Fri, 28 Nov 2014 15:25:39 -0200 (UYST)
I have send an email past wednesday.
I have problema with a match definition.
I have written the definition that I adjoin
below,
I use arguments smaller in the
recursive call but Coq does not accept
it.
I explain what has happen in comments
inside the definition.
(* I have written the definitions below:*)
Variable A:Type.
Parameter R: A -> A -> bool.
Lemma not_le_2(a:A)(m:nat) :
not (le (S (S m))
(length (cons a nil))).
unfold length.
apply gt_not_le.
apply gt_n_S.
apply gt_Sn_O.
Qed.
Lemma zero_succ (n:nat) : not(O=(S n)).
intro.
apply (le_Sn_0 n).
rewrite H.
apply le_n.
Qed.
Lemma nil_cons (x:A)(l:list A)
: not (nil=cons x l).
intro.
discriminate.
Qed.
(* I want to define a function element that given a list
l and a natural number n returns the element in the
list at the n-th position. I have put the preconditions
to the function as hypothesis of function types. *)
(* I get the following error message :
Recursive definition of element is ill-formed.
I don't understand why does not accept the recursive
call since it is applied to elements smaller *)
Fixpoint element (l:list A)(n:nat){struct l}:
not (nil=l) -> not (O=n)
-> le n (length l) -> A:=
match l, n with
| nil, _ => (fun q =>
fun p =>
fun r => (False_rec
A
(q (refl_equal nil))))
| _, O => (fun q =>
fun p =>
fun r => (False_rec
A
(p (refl_equal O))))
| (cons x l1),(S O) =>
(fun q =>
fun p =>
fun r => x)
| (cons x nil), (S (S m)) => (fun q =>
fun p =>
fun r => (False_rec
A
((not_le_2 x m) r)))
| (cons x (cons y l1)), (S (S m)) =>
(fun q =>
fun p =>
fun r =>
(element (cons y l1) (S m)
(nil_cons y l1)
(zero_succ m)
(le_S_n (S m)
(length (cons y l1)) r)))
end.
Regards, Patricia.
