Re: [Coq-Club] (user experience report) "Proof assistants as routine tools", Neil Strickland
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] (user experience report) "Proof assistants as routine tools", Neil Strickland
- Date: Mon, 1 Dec 2014 13:17:43 +0100
On Sun, Nov 30, 2014 at 01:40:18PM +0200, Ilmārs Cīrulis wrote:
> Probably a bit offtopic.
> It was easy to prove "(exists n, forall p, prime p -> p <=n) -> False".
> But I had a problems proving "(forall n, exists p, prime p /\ p > n".
That is exactly what the proof Cyril and myself pointed to shows.
Lemma prime_above m : {p | m < p & prime p}.
Here we have a sigma-type in Type (denoted with {x | P x}) instead of Prop
(denoted with exists), hence we really construct the witness.
> Do you have any hints? (Also, what does that SSReflect proof do?)
The proof uses some facts from the math comp library, namely
Lemma pdivP n : n > 1 → {p | prime p & p %| n}. (* %| means divides *)
Lemma gtnNdvd n d : 0 < n → n < d → (d %| n) = false.
The theories used are mostly here:
http://ssr.msr-inria.inria.fr/doc/mathcomp-1.5/MathComp.prime.html
http://ssr.msr-inria.inria.fr/doc/mathcomp-1.5/MathComp.div.html
I guess you want to look at the pdiv function, that is the one computing
the witness. Its correctness is not proved directly, but is rather a
consequence of the correctness of the algorithm producing a prime
decomposition (pdiv just picks the smallest item in the decomposition).
Best,
Enrico Tassi
- Re: [Coq-Club] (user experience report) "Proof assistants as routine tools", Neil Strickland, Frédéric Blanqui, 12/01/2014
- Re: [Coq-Club] (user experience report) "Proof assistants as routine tools", Neil Strickland, Cedric Auger, 12/01/2014
- <Possible follow-up(s)>
- Re: [Coq-Club] (user experience report) "Proof assistants as routine tools", Neil Strickland, Enrico Tassi, 12/01/2014
- Re: [Coq-Club] (user experience report) "Proof assistants as routine tools", Neil Strickland, Bas Spitters, 12/01/2014
