- From: Gabriel Scherer <gabriel.scherer AT gmail.com>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Proving 1/2n + 1/2n = 1/n for all n.
- Date: Wed, 10 Dec 2014 10:22:49 +0100
Interestingly, a more general statement (using divisions on rationals instead of the primitive # construction) is readily proved by the 'field' tactic:
Require Import QArith.
Goal forall k, ~(k == 0) -> (1 / k) == (1 / ((1+1) * k)) + (1 / ((1+1) * k)).
intros. field. auto.
Qed.
Qed.
On Wed, Dec 10, 2014 at 9:09 AM, Kyle Stemen <ncyms8r3x2 AT snkmail.com> wrote:
So if you pass 0 for n, the theorem simplifies to (1/1) = (1/2) + (1/2).Good question.The Pos.of_nat function converts a natural number (which includes 0) into a positive number (does not include 0). In the case of 0, Pos.of_nat is defined to return 1.
Q is the rational type in coq. It is defined as Z / positive.Coq < Eval compute in (Pos.of_nat 0).
= 1%positive
: positiveOn Tue, Dec 9, 2014 at 11:53 PM, Marco Servetto marco.servetto-at-gmail.com |coq-club/Example Allow| <rhl7blvknt AT sneakemail.com> wrote:1/2n + 1/2n = 1/n for all n.
I'm wrong or this does not holds for n=0?
On 10 December 2014 at 13:51, Kyle Stemen <ncyms8r3x2 AT snkmail.com> wrote:
> I haven't found a good book or tutorial for rationals in coq. Let me know if
> you find one.
> Is this the proof you're looking for?
> Theorem simple: forall n:nat,
> (1 # Pos.of_nat n) == (1 # (2*Pos.of_nat n)) + (1 # (2 * Pos.of_nat n)).
> Proof.
> intros.
> unfold Qplus.
> unfold Qeq.
> simpl.
> rewrite -> Pos.add_diag.
> rewrite -> Pos.mul_comm.
> reflexivity.
> Qed.
> Now I've got a follow up question that maybe someone else can answer. Why
> doesn't SearchPattern find the lemmas in the Pos module?
> Coq < Require Import QArith.
> [Loading ML file z_syntax_plugin.cmxs ... done]
> [Loading ML file quote_plugin.cmxs ... done]
> [Loading ML file newring_plugin.cmxs ... done]
> [Loading ML file omega_plugin.cmxs ... done]
> Coq < SearchPattern (_ * _ = _ * _)%positive.
> Coq < Check Pos.mul_comm.
> Pos.mul_comm
> : forall p q : positive, (p * q)%positive = (q * p)%positive
> Coq < SearchPattern (_ * _ = _ * _)%nat.
> mult_comm: forall n m : nat, (n * m)%nat = (m * n)%nat
> mult_assoc_reverse: forall n m p : nat, (n * m * p)%nat = (n * (m * p))%nat
> mult_assoc: forall n m p : nat, (n * (m * p))%nat = (n * m * p)%nat
> On Tue, Dec 9, 2014 at 5:51 PM, Daniel Galvez dt.galvez-at-gmail.com
> |coq-club/Example Allow| <w75rw6tgit AT sneakemail.com> wrote:
>> Hello,
>> A subgoal in a proof of mine is the following:
>> forall n:nat, (1 # Pos.of_nat n) == (1 # (2*Pos.of_nat n)) + (1 # (2 *
>> Pos.of_nat n)).
>> That is, 1/n = 1/(2n) + 1/(2n).
>> The domain of discourse here is the rationals. Perhaps there is something
>> I am
>> not seeing being new to Coq, but I would expect a simple call to some
>> tactic
>> like compute to dismiss this. I make progress in the code below by doing
>> induction on n, but am at a complete as for what to do in the inductive
>> case.
>> (Note that the edge case of n = 0 does not invalidate this, as Post.of_nat
>> 0 =
>> 1.)
>> Theorem simple:
>> Pos.of_nat n)).
>> intros.
>> unfold Qplus.
>> unfold Qeq. simpl.
>> induction n.
>> simpl. reflexivity.
>> Does anyone have a suggestion as to where I should look for completing
>> this
>> proof?
>> Thank you,
>> Daniel Galvez
- [Coq-Club] Proving 1/2n + 1/2n = 1/n for all n., Daniel Galvez, 12/10/2014
- Re: [Coq-Club] Proving 1/2n + 1/2n = 1/n for all n., yi lu, 12/10/2014
- Re: [Coq-Club] Proving 1/2n + 1/2n = 1/n for all n., Kyle Stemen, 12/10/2014
- Re: [Coq-Club] Proving 1/2n + 1/2n = 1/n for all n., Marco Servetto, 12/10/2014
- Re: [Coq-Club] Proving 1/2n + 1/2n = 1/n for all n., Gabriel Scherer, 12/10/2014
- Re: [Coq-Club] Proving 1/2n + 1/2n = 1/n for all n., Laurent Théry, 12/10/2014
- Re: [Coq-Club] Proving 1/2n + 1/2n = 1/n for all n., Cedric Auger, 12/10/2014
