- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Syntax for paraneterized Type Class instances
- Date: Tue, 16 Dec 2014 12:39:14 +0100
Hi Michael,
This prime is a backquote, I think it is described in a section about generalizable variables, or at least the command Generalizable Variables A B which you need here should be in the command index. Didn't you get at least one error saying something close to "unbound and non-generalizable variable A"?
Best,
-- Matthieu
-- Matthieu
Le mardi 16 décembre 2014, <michael.soegtrop AT intel.com> a écrit :
Dear Coq Users,
I don't understand the syntax given in chapter 19.3 of the reference manual:
Instance prod_eqb ‘(EA : EqDec A, EB : EqDec B) : EqDec (A * B)
What is the meaning of the prime here? Is this an abbreviation for this:
Instance prod_eqb {A B : Type} (EA : EqDec A) (EB : EqDec B) : EqDec (A * B)
Also I have problems to make Coq parse the syntax given in the manual with all
3 prime variants on my keyboard (`'´) and the prime used in the manual (‘).
Is there a description for this syntax in the reference manual?
Thanks & Best regards,
Michael
- [Coq-Club] Syntax for paraneterized Type Class instances, michael.soegtrop, 12/16/2014
- Re: [Coq-Club] Syntax for paraneterized Type Class instances, Matthieu Sozeau, 12/16/2014
- RE: [Coq-Club] Syntax for paraneterized Type Class instances, Soegtrop, Michael, 12/16/2014
