coq-club - Re: [Coq-Club] Store several theorems in a kind of Record
  • From: CHAUVIN Barnabe <barnabe.chauvin AT gmail.com>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Store several theorems in a kind of Record
  • Date: Mon, 12 Jan 2015 21:06:39 +0100
I answer myself :
jrw give me a very solution on IRC :
Define two theorems (including the case hypothesis) :
Theorem thm1 : P=0 -> ...
Theorem thm2 : P<>0 -> ...
(For example, if the different cases depend on the value of P)
And then use an extra theorem that include both :
Theorem thm : ...
Which is easy to prove with [destruct]
On 12/01/2015 20:51, CHAUVIN Barnabe wrote:
Hello club !
I am trying to define some theorems, and I am having difficulty :
Let's say I have a variable P.
I want to define a theorem that depend on the value of P (If it is zero or not actually). The problem is that it makes the theorem very big (i.e. a lot of hypothesis), because of the different cases.
(The proof also depend on that value, but this is not the main problem).
Thus, I was wondering whether it would be possible to define a kind of record (By analogy with [Record]) that would store several theorems (In fact, it would to the same theorems, but with a value-hypothesis diference).
Each of these theorems would have a condition (a kind of predicate) that would decide which one has to be used when using [apply] for example.
Actually, I can define these theorems as usual, by using different names (like theorem1, theorem2 ...), but I really want only one name, to be able to use it as a single theorem in other proofs (like when using [apply] for instance).
Thanks for your help, I don't know if it is really clear ... I don't know at all if it exists or not, that's why I am asking here ..
Barnabé Chauvin
