- From: Jean-Francois Monin <jean-francois.monin AT imag.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] a question about well-formedness of inductive definitions
- Date: Thu, 22 Jan 2015 17:35:26 +0100
- Mailscanner-null-check: 1422549328.30195@hwFk8umnXkJIuMa8nSz0zQ
Hello,
The first line of your definition has n as a fixed given nat:
it is the expected to define what is, for any other nat i,
to be such that ge n i.
But your last line relates (S n) to some nat instead of n.
Tehrefore n should not be fixed from the beginning and
you should try a definition starting with
Inductive ge : nat -> nat -> Prop :=
Jean-Francois
On Thu, Jan 22, 2015 at 04:06:02PM +0000, Matej Kosik wrote:
> Hello,
> While reading Section 4.5.3 of the Reference Manual (Well-formed inductive
> definitions)
> and while going through the standard library, I have try to define this:
> (* a superfluous definition of "ge" predicate *)
> Inductive ge (n:nat) : nat -> Prop :=
> | ge_n : ge n n
> | ge_S : forall m:nat, ge n m -> ge (S n) m.
> Coq rejects that definition with a message:
> Error: Last occurrence of "ge" must have "n" as 1st argument in
> "forall m : nat, ge n m -> ge (S n) m".
> That is somewhat surprising because the definition (despite being
> superfluous in practise) seems plausible to me.
> If I may, I would like to ask:
> - which side-condition of the W-Ind rule (?) the definition above breaks?
> - why that kind of restriction must be enforced?
- [Coq-Club] a question about well-formedness of inductive definitions, Matej Kosik, 01/22/2015
- Re: [Coq-Club] a question about well-formedness of inductive definitions, Jean-Francois Monin, 01/22/2015
- Re: [Coq-Club] a question about well-formedness of inductive definitions, Pierre Courtieu, 01/22/2015
- Re: [Coq-Club] a question about well-formedness of inductive definitions, Maxime Dénès, 01/22/2015
