coq-club - [Coq-Club] Proving that sections of primitive recursive functions are primitive recursive
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Proving that sections of primitive recursive functions are primitive recursive
  • Date: Mon, 26 Jan 2015 12:24:03 +0000
(* I'm learning about primitive recursive functions and trying to formalize some of the material in Coq. Specifically, I want to prove that any section of a primitive recursive function is also primitive recursive, because this property comes in handy for proving other theorems. *)
(* Before getting to the problem, here are the definitions used to state the theorem. Everything from this point to PRF_proper is just definition of primitive recursive function in Coq. You can skip it if unnecessary. *)
Require Import NaryFunctions.
Definition nfun (n : nat) : Type :=
nat ^^ n --> nat.
(* Although not strictly necessary, I decided to have some fun with combinators... *)
(* \ a b c => a c b, the cardinal. *)
Definition cardinal {X Y Z : Type }
(f : X -> Y -> Z) : Y -> X -> Z :=
fun y x => f x y.
(* \ a b => a b b, the warbler. *)
Definition warbler {X Y : Type }
(a : X -> X -> Y) (b : X ) : Y :=
a b b.
(* \ a b => b a, the thrush. *)
Definition thrush {X Y : Type }
(a : X) (b : X -> Y ) : Y := b a.
(* \ a b => b a, the kestrel. *)
Definition kestrel {X Y : Type }
(a : X) (b : Y ) : X := a.
(* Constants. *)
Fixpoint const (n m : nat) : nfun n
:= match n return nfun n with
| O    => m
| S n' => kestrel (const n' m)
end.
(* Projections. *)
Fixpoint proj (n m : nat) : nfun n
| O    => O
| S n' =>
  match m with
  | O    => const (S n') O
  | S O  => const n'
  | S m' => kestrel (proj n' m')
  end
end.
(* The following 2 definitions are used to define composition. *)
Fixpoint delay {X Y Z : Type} {n : nat} :
(Z -> X ^^ n --> (Z -> Y))
-> X ^^ n --> (Z -> Y) :=
match n return
with
| O    => warbler
| S n' => fun f g
       => delay (fun z => f z g)
end.
Fixpoint dist {X Y : Type}
{Z : Type} {n : nat} :
(X ^^ n --> Y) -> (Z -> X) ^^ n --> (Z -> Y) :=
match n return
with
| O    => kestrel
| S n' => fun f g => delay (fun z
       => dist (f (g z)))
end.
(* Composition. *)
Fixpoint comp {X Y Z : Type} (n m : nat)
(f : X ^^ n --> Y) :
(Z ^^ m --> X) ^^ n --> (Z ^^ m --> Y) :=
match m return
with
| O    => f
| S m' => dist (comp n m' f)
end.
(* Used for defining primitive recursion. *)
Fixpoint stitch {X Y Z: Type} {n : nat} :
(X ^^ n --> Y) -> (Y -> X ^^ n --> Z)
-> (X ^^ n --> Z) :=
match n return
-> (X ^^ n --> Z)
with
| O    => thrush
| S n' => fun f g x
       => stitch (f x) (cardinal g x)
end.
(* Primitive recursion. *)
Fixpoint rec {n : nat} (g : nfun n)
(h : nfun (S (S n))) (m : nat) :
nfun n :=
match m with
| O    => g
| S m' => stitch (rec g h m') (cardinal h m')
end.
(* PRF, the predicate which asserts that a certain function over natural numbers is primitive recursive. It is indexed by an extra counter m due to limitations regarding strict positivity. An n-ary function f is primitive recursive in the usual sense if PRF 0 n f. If PRF m n f /\ m <> 0, it means that m more functions (which are n-ary and primitive recursive) need to be applied to f to make it properly primitive recursive. *)
Inductive PRF : forall (n m : nat),
(nfun m ^^ n --> nfun m) -> Prop :=
| PRF_S : PRF 0 1 S
| PRF_cst : forall n m, PRF 0 n (const n m)
| PRF_prj : forall n m, 0 <> m
  -> m <= n -> PRF 0 n (proj n m)
| PRF_cps : forall n m
  (f: nfun m),
  PRF 0 m f ->
  PRF m n (comp m n f)
| PRF_app : forall n m f g,
  PRF (S m) n f -> PRF 0 n g
  -> PRF m n (f g)
| PRF_rec : forall n f g,
  PRF 0 n f -> PRF 0 (S (S n)) g
  -> PRF 0 (S n) (rec f g).
Hint Constructors PRF.
(* A shorthand which hides the m index. *)
Definition PRF_proper {n : nat}
(f : nfun n) : Prop :=
PRF 0 n f.
(* Now the problematic part. I want to prove that for any (n+1)-ary primitive recursive function f, its n-ary section (f x) is also primitive recursive, for all x. Intuitively this is obvious, because the composition f(x, proj^n_2, proj^n_3, ... proj^n_n) is equivalent to (f x) and clearly primitive recursive. But I want to prove this in Coq, and I found this to be unexpectedly difficult. *)
Lemma PRF_section : forall (n x : nat )
(f : nfun (S n)),
PRF 0 (S n) f -> PRF 0 n (f x).
(* I first tried proving this by induction on n, which didn't work out because having
forall x f, PRF 0 (S n) f -> PRF 0 n (f x).
in the context is not very helpful for proving
forall x f, PRF 0 (S (S n)) f -> PRF 0 (S n) (f x).
If there is a proof by induction on n, that would be the most straightforward solution (please let me know if you find one), but I couldn't see how to do it. The second idea I had was to perform an induction on the proposition PRF 0 (S n) f. So I tried *)
intros.
generalize dependent x.
induction H.
(* but Coq tells me that the induction is impossible because it is ill-typed. Is there any way around this? *)
  • [Coq-Club] Proving that sections of primitive recursive functions are primitive recursive, Seul Baek, 01/26/2015
