coq-club - Re: [Coq-Club] Gentzen proof and Kantor ordering
  • From: Neelakantan Krishnaswami <n.krishnaswami AT cs.bham.ac.uk>
  • To: coq-club AT inria.fr
  • Cc: Types list <types-list AT lists.seas.upenn.edu>
  • Subject: Re: [Coq-Club] Gentzen proof and Kantor ordering
  • Date: Thu, 29 Jan 2015 15:10:49 +0000
  • Organization: School of Computer Science, University of Birmingham
Hello,
Paul Taylor has written about how to formulate ordinals in constructive
set theory in his paper "Intuitionistic Sets and Ordinals" [1].
The fixed point theorem Taylor mentions in the introduction to this
paper can be proved by the elegant argument of Pataraia (which Pataraia
himself never published, but Martin Escardo reproduced the proof in his
paper "Joins in the frame of nuclei" [2]).
Best,
Neel
[1] http://www.monad.me.uk/~pt/ordinals/intso.pdf
[2] http://www.cs.bham.ac.uk/~mhe/papers/hmj.pdf
On 29/01/15 14:59, roux cody wrote:
Dear Vladimir,
Coq is more than powerful enough to prove well ordering of epsilon zero,
*for a constructive notion of well ordering*. This is usually defined by
*accessibility*: if some property about ordinals is closed by successor
and limits, then it holds for all ordinals.
Sadly, this is not constructively equivalent to the fact that any subset
of ordinals has a least element.
The n-lab seems to sum the situation up quite nicely:
http://ncatlab.org/nlab/show/well-founded+relation
Without references I'm afraid.
Note that the constructive formulation of well-foundedness is sufficient
for most applications! What application did you have in mind?
Best,
Cody
On Thu, Jan 29, 2015 at 7:46 AM, Vladimir Voevodsky
<vladimir AT ias.edu
<mailto:vladimir AT ias.edu>>
wrote:
If I recall correctly the ordinal numbers smaller than epsilon zero
can be represented by finite rooted trees (non planar). It is then
not difficult to describe constructively the ordinal partial
ordering on them. Gentzen theorem says that if this partial ordering
is well-founded then Peano arithmetic is consistent.
What can we prove about this ordering in Coq?
Can it be shown that any decidable subset in the set of trees that
is inhabited has a smallest element relative to this ordering?
If not then can the system of Coq me extended *constructively* (i.e.
preserving canonicity) so that in the extended system such smallest
elements can be found?
Vladimir.
