- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] How to show off Coq
- Date: Sat, 31 Jan 2015 13:49:48 +0100
On 30/01/15 21:01, Eric Mullen wrote:
> If you wanted to give a 10 minute demo to show off how cool Coq was, what
> example would you use?
Below is an example that I used several times with professional
engineers. It consists in proving the correctness of a simple
arithmetic circuit (ripple-carry adder). It assumes the audience
knows a bit about computer arithmetic and circuits. You can get some
pretty interesting questions from the audience, e.g. "but can I make
sure my two input numbers have the same number of bits?" (dependent
types here we come!).
More advanced examples that I sometimes use:
- The Majority algorithm of Boyer and Moore
(http://www.cs.utexas.edu/users/moore/best-ideas/mjrty/index.html)
- Compilation of arithmetic expressions to a stack machine.
- Xavier Leroy
(** Tutorial 1: adder circuits. *)
Require Import Bool. (** The library for booleans *)
Require Import List. (** The library for lists *)
Require Import ZArith. (** The library for integer arithmetic (type Z) *)
Open Scope Z_scope. (** Using the notations for type Z *)
(** The boolean equations for a full adder circuit:
- 3 inputs: two bits A, B and a carry in
- 2 outputs: one bit and a carry out.
Definition adder_sum (A B Cin: bool) : bool :=
xorb (xorb A B) Cin.
Definition adder_carry_out (A B Cin: bool) : bool :=
orb (andb (xorb A B) Cin) (andb A B).
Definition adder (A B Cin: bool) : bool * bool :=
(adder_sum A B Cin, adder_carry_out A B Cin).
(** The integer denoted by a single bit A. *)
Definition val_bit (A: bool) : Z :=
if A then 1 else 0.
(** Checking that the full adder does compute the sum of its 3 inputs. *)
Theorem adder_correct:
forall A B Cin,
val_bit (adder_sum A B Cin) + val_bit (adder_carry_out A B Cin) * 2
= val_bit A + val_bit B + val_bit Cin.
Proof.
destruct A; destruct B; destruct Cin; auto.
Qed.
(** Composing full adders to sum vectors of bits. *)
Fixpoint ripple_carry_adder (A B: list bool) (Cin: bool) : list bool :=
match A, B with
| A1 :: A', B1 :: B' =>
adder_sum A1 B1 Cin ::
ripple_carry_adder A' B' (adder_carry_out A1 B1 Cin)
| _, _ =>
Cin :: nil
end.
(** The integer denoted by a vector of bits A.
Least-significant bit comes first. *)
Fixpoint val_bits (A: list bool) : Z :=
match A with
| nil => 0
| A1 :: A' => val_bit A1 + val_bits A' * 2
end.
(** Checking that the ripple carry adder does compute the sum of its inputs.
Theorem ripple_carry_adder_correct:
forall A B Cin,
length A = length B ->
val_bits (ripple_carry_adder A B Cin) =
val_bits A + val_bits B + val_bit Cin.
Proof.
induction A; destruct B; simpl; intros.
- (* A and B are nil: base case *)
omega.
- (* A is nil, B is not: contradicts the hypothesis on lengths *)
exfalso. omega.
- (* B is nil, A is not: contradiction *)
exfalso. omega.
- (* A and B are not nil: inductive case *)
rewrite IHA.
specialize (adder_correct a b Cin); intros.
omega.
omega.
Qed.
(*Print ripple_carry_adder_correct.*)
- [Coq-Club] How to show off Coq, Eric Mullen, 01/30/2015
- Re: [Coq-Club] How to show off Coq, Adam Chlipala, 01/30/2015
- Re: [Coq-Club] How to show off Coq, Daniel Schepler, 01/31/2015
- Re: [Coq-Club] How to show off Coq, John Wiegley, 01/30/2015
- Re: [Coq-Club] How to show off Coq, Christopher Dutchyn, 01/30/2015
- Re: [Coq-Club] How to show off Coq, Matej Grabovský, 01/30/2015
- Re: [Coq-Club] How to show off Coq, Xavier Leroy, 01/31/2015
- Re: [Coq-Club] How to show off Coq, Louis Garde, 01/31/2015
- Re: [Coq-Club] How to show off Coq, Gérard Huet, 01/31/2015
- Re: [Coq-Club] How to show off Coq, Greg Morrisett, 01/31/2015
