coq-club - Re: [Coq-Club] Problem with "once" tactical and "constructor"
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Problem with "once" tactical and "constructor"
  • Date: Sat, 31 Jan 2015 16:45:09 -0500
On 01/31/2015 02:38 PM, Jason Gross wrote:
How does one determine when goals can share an evar? You gave a tactic
that constructs an evar shared by all the goals, so you could presumably
construct a tactic that requires backtracking across goals.
There are "hacks" that purposefully share evars that aren't even in goals to begin with, using tricks that name evars explicitly like "pose(x:=?E)". That "any" tactical I wrote is an example. However, in such cases, one would know that one was doing such "evar hacks", and if there was some "sync" tactical, would use that - like tac1; sync; tac2 to force the sequence to not be [> tac1; tac2..], but instead be [>tac1..];[>tac2..]. Or, maybe just repurpose the [>tac1..];[>tac2..] form to be the case where no backtracking optimization pruning is done.
Another point about the importance of this problem: automation tactics such as (e)auto perform backtracking (in 8.5) as if the tactic hints they use are strung together with the normal sequencing tactical: tac1; tac2; tac3. So this is a problem for proof automation as well as explicit proof scripts. Maybe even more so, as one would perhaps be more likely to use tactics with multiple successes as hints than in explicit proof scripts, as well as to be less informed of the possibility of combinatorial explosion as a result (since the hints are scattered).
I agree, though, Coq should not backtrack across goals that naively share
no evars. Perhaps there should be a setting that disables this pruning?
Yes - maybe have Coq do some very simple testing. The naive case would be: if there is no ?E for which ?E appears in both goals (or if ?E is one of those goals), then assume that they can be backtracked independently. In the case where ?E is one of the goals - that goal might need to be backtracked from others that mention ?E, but not vice versa.
A more advanced version that might still be easy to implement: If a tactic doesn't instantiate an evar, then even though an evar is present that is shared with some other goal, backtracking of that tactic on a goal can be done independently of other goals at least until some alternative success of that tactic does instantiate the evar. (In general, tactics that don't instantiate evars are "friendlier" to proof search - a motivation for enhancement request #3872.). On the "receiving" side, if a tactic "consumes" an evar without referring to its instantiation - as referring to evar(n:nat) as a nat regardless of its value would do - then backtracking across to goals that do the instantiation is useless.
Even more refinement is possible - because the issue is really with identical instances of the same evar, not with distinguishable instances of the same evar - however, in 8.5, Coq doesn't seem to handle this in the most rigorous way (see bug #3918). Ideally, Coq should not force an instance of an evar to be a possibly translated instantiation from a different instance of the same evar if there is some discriminable difference between the two instances - in other words, if one could instead instantiate the evar with a match expression that has different values for the branches that represent those two instances. If Coq behaved that way, then there would be no need to backtrack across goals that shared evars and even instantiated them, as long as the instances were discriminably different.
[there seems to be some similarity in this problem to those in concurrent databases, which was my previous profession - or maybe all problems just look alike after a while]
-- Jonathan
