coq-club - Re: [Coq-Club] Force automation to ignore a hypothesis
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Force automation to ignore a hypothesis
  • Date: Sun, 01 Feb 2015 16:22:19 -0500
On 02/01/2015 03:58 PM, Jonathan Leivent wrote:
On 02/01/2015 03:43 PM, Joey Dodds wrote:
Hi,
I'm trying to do a mutually inductive proof where Coq puts the lemmas you
are trying to prove above the line and you have to be careful where to
apply them or you will fail to QED.
My automation keeps using them, and I was wondering if there was a way to
define a tactic to temporarily make them unusable. My first attempt was
rewriting them into an opaque identity function, but it seems like auto and
apply are happy to ignore opacity and unfold the definition anyways.
Thanks,
Joey
I have a way to do this in 8.5, but it's a bit of a hack (again). I also requested this feature as enhancement #3845.
I'll extract the hiding tactic from some other stuff I'm working on, and post it momentarily...
-- Jonathan
Attached. Unfortunately, this specific tactic includes a lot of the infrastructure I'm still building. The example at the very end uses the tactic "vgoal" (included) to display the current goal with two hypotheses (n2 and n3) hidden. To use, just substitute some other tac in the invocation "hyps {non-empyt list of hyps to hide} => hide_hyps tac"
Note that this hiding technique should be able to prevent any automation from using the hidden hypotheses. Here's the output with n2 and n3 hidden:
n0 : nat
n1 : nat
hidden : (Type -> Type)
n2 : (hidden nat)
n3 : (hidden nat)
n4 : nat
True
Since the hidden function is bodyless in this goal, there is no way for automation to make use of the hidden hyps. The "hack" involves how to recover those hidden hypotheses.
-- Jonathan
Ltac lasthyp :=
  lazymatch goal with H:_ |- _ => constr:(H) end.
Ltac revert_clearbody1 H := try clearbody H; revert H.
Ltac harvest_hyps harvester :=
  constr:($(harvester; constructor)$ : True).
Tactic Notation "harvest" tactic3(harvester) "=>" tactic3(tac) :=
  let hs := harvest_hyps harvester in
  tac hs.
Ltac revert_clearbody_all :=
  repeat revert_clearbody1 lasthyp.
Ltac allhyps := harvest_hyps revert_clearbody_all.
Tactic Notation "hyps" "=>" tactic3(tac) :=
  harvest revert_clearbody_all => tac.
Tactic Notation "hyps" ne_hyp_list(hs) "=>" tactic3(tac) :=
  harvest generalize hs => tac.
Ltac next_hyp hs step last :=
  lazymatch hs with
  | (?hs' ?H) => step H hs'
  | _ => last
  end.
Ltac loop tac hs :=
  idtac;
  let rec step H hs := tac H; next_hyp hs step idtac in
  next_hyp hs step idtac.
Ltac reorder hs :=
  let totop H := try move H at top in
  loop totop hs.
Tactic Notation "Reorder" tactic4(tac) :=
  hyps => fun hs => tac; reorder hs.
Ltac intro_to H :=
  intro;
  first [constr_eq H lasthyp | intro_to H].
Ltac eclear_except hs :=
  let stop:=fresh "stop" in
  generalize I as stop;
  (repeat let H:=lasthyp in
    lazymatch hs with
    | context[H] => revert H
    | _ => first [clear H|revert H]
    end);
  intro_to stop;
  clear stop.
Ltac hide_hyps tac hs :=
  try (is_evar ?__Unhider;
       fail 1 "hide_hyps: The evar name ?__Unhider is being used");
  let hider := fresh "hidden" in
  pose (hider := (fun T=>T): Type -> Type);
  let hidetype H := let T := type of H in
                    change T with (hider T) in H in
  loop hidetype hs;
  assert True as _;
  [eclear_except hider|];
  [|clearbody hider; tac];
  [refine (let unhide := ?[__Unhider] : hider=fun T=>T in _) | ..];
  [| |Reorder pose proof ?__Unhider as -> ..];
  [reflexivity|exact I|..].
Ltac get_value H := eval cbv delta [H] in H.
Ltac vgoal :=
  idtac; (*prevents early eval*)
  match reverse goal with
    | H : ?T |- _ =>
      first[let v := get_value H in
            idtac H ":=" v ":" T
           |idtac H ":" T];
      fail
    | |- ?G =>
      idtac "======"; idtac G; idtac ""
  end.
Goal True.
do 5 pose proof 0 as ?n0.
hyps n2 n3 => hide_hyps vgoal.
