coq-club - Re: [Coq-Club] How to show off Coq
  • From: David Pichardie <david.pichardie AT ens-rennes.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] How to show off Coq
  • Date: Tue, 3 Feb 2015 12:59:32 +0100
I like to use an example with efficient data structures, without maths and
with good automatisation.
David
(** You need Coq 8.4 and a Coq IDE like CoqIDE or the
Proof General emacs-mode *)
(** Our first Coq programs *)
(** In this tutorial will implements simple maps *)
Module Type MAP.
(** the type of map keys *)
Parameter key : Type.
(** the type of map elements *)
Parameter elt : Type.
(** the type of maps *)
Parameter t : Type.
(** [default] is the default element in a map *)
Parameter default: elt.
(** [get m k] returns the elements that is binded with key [k] *)
Parameter get: t -> key -> elt.
(** [empty] is a map that binds every keys to [default] *)
Parameter empty: t.
(** [set m k e] returns a new map that contains the same
bindings as map [m] except for key [k] that is now binded with
the element [e] *)
Parameter set: t -> key -> elt -> t.
End MAP.
(** Observe that we use the same keyword for types and operators.
What we think as types here, are term of type [Type]. *)
(** To implement this interface, we will need some basic data structures *)
(** Peano natural numbers *)
Inductive nat :=
| O (* zero is a nat *)
| S (n:nat) (* a successor of a nat is a nat *)
(** In Ocaml we would have written [type nat = | O | S of nat] *)
(** [nat] is a type. It is inhabited by terms
like O, (S O), (S (S O)), ... *)
(** The command [Check] gives the type of a term. *)
Check O.
Check (S (S (S (S O)))).
(** Coq already provides this basic data structure in its
library. We will remove our version and load Coq's
version instead. *)
Reset nat.
Require Import Arith.
Check O.
(** Observe that Coq now pretty-prints our terms in
the *response* window *)
(** We will also use other data structures like list and string.
We load the corresponding libraries but we do not detail their
content here *)
Require Import String.
Require Import List.
Open Scope string_scope. (* Will facilitate string input *)
(** We now begin the implementation of a MAP interface for the
special case were keys are natural numbers and elements are string *)
Module NatStringMap <: MAP
with Definition key := nat
with Definition elt := string.
Definition key := nat.
(** A map will be a list of string [s_0 :: ... :: s_n] where
a number [i] is binded with [s_i] if [i <= n] or with the
default element otherwise *)
Definition t := list string.
(** Note: a list is either the empty list [nil]
or a non-empty list of the form [x :: q] with
[x] the head of the list and
[q] the queue of the list
(* We arbitrarily choose the empty string as the default element *)
Definition default := "".
Fixpoint get (l:list string) (n:nat) : string :=
match l, n with
| nil, _ => default
| x::_, O => x
| _::q, S m => get q m
end.
Definition empty : t := nil.
Fixpoint set (l:list string) (n:nat) (s:string) : list string :=
match l, n with
| nil, O => s :: nil
| nil, S m => default :: set nil m s
| _ :: q, O => s :: q
| x :: q, S m => x :: set q m s
end.
End NatStringMap.
Notation "m [ k ]" := (NatStringMap.get m k) (at level 20).
Notation "m +{ k ↦ e }" := (NatStringMap.set m k e) (at level 20).
Notation "{}" := (NatStringMap.empty) (at level 20).
Compute ({} +{0 ↦ "zero" } +{2 ↦ "two" } +{3 ↦ "three" } [4]).
Compute ({} +{0 ↦ "zero" } +{2 ↦ "two" } +{3 ↦ "three" } [3]).
Compute ({} +{0 ↦ "zero" } +{2 ↦ "two" } +{3 ↦ "three" } [2]).
Compute ({} +{0 ↦ "zero" } +{2 ↦ "two" } +{3 ↦ "three" } [1]).
Compute ({} +{0 ↦ "zero" } +{2 ↦ "two" } +{3 ↦ "three" } [0]).
(** That's a good start but, since we are in Coq, and not in OCaml, we can
actually make our comments be formal statements *)
Reset MAP.
Module Type MAP.
Parameter t : Type.
(** the map that binds every keys to [default] *)
Parameter empty: t.
Parameter empty_spec: forall k, get empty k = default.
(** [set m k e] returns the a new map that contains the same
the element [e] *)
Parameter get_set_new: forall k m e,
get (set m k e) k = e.
Parameter get_set_old: forall k m e k',
k'<>k -> get (set m k e) k' = get m k'.
(** Note that [->] means "implies" and [<>] means "different" here. *)
End MAP.
match l, n with
| nil, _ => default
| x::_, O => x
end.
match l, n with
| nil, O => s :: nil
| _ :: q, O => s :: q
end.
(** This time we can't end the module so easily because we have proof
to do ! *)
(** The command we use to build an interactive proof are called tactics.
The set of Coq tactics is rather large. We will only expose a limited
number
of them in this tutorial. When the remaining proof is easy we will use
a custom tactic that force Coq to search alone the proof *)
(** We call this tactic [go] and we do not explain its content *)
Ltac go := try congruence; eauto; try econstructor (solve[go]).
Lemma empty_spec: forall k, get empty k = default.
Proof.
go.
Qed. (* [Qed] only succeeds if the system accept our proof *)
Lemma get_set_new: forall k m e,
Proof.
intros.
destruct k.
- simpl.
destruct m.
+ simpl.
go.
+ simpl.
go.
- simpl.
destruct m.
simpl.
(** we did not do much progress... *)
Abort. (* we abort the current proof *)
Proof.
induction k; intros.
- simpl.
destruct m.
+ simpl.
go.
+ simpl.
go.
- simpl.
destruct m.
+ simpl.
apply IHk. (* or [go] *)
+ simpl.
go.
(* ok, but since we have apply very similar on each branch of the
proof we can put a more compact (and robust) script*)
Abort.
Proof.
induction k; destruct m; simpl; go.
Qed.
Lemma get_set_old: forall k m e k',
Proof.
induction k; destruct m; destruct k'; simpl; go.
(* only one remaining goal *)
intros.
rewrite IHk; go.
Qed.
End NatStringMap.
(* We may have a look at the OCaml extracted version *)
Extraction NatStringMap.
(** In the previous implementation [get] and [set] have a linear
complexity (both in time and space) with respect to the size
of the biggest inserted key. We now seek for an implementation
with a logarithmic complexity *)
(* The custom tactic [go] was not exported outside the Module when we
closed it. We now redefine it here. *)
(** We need first to build some data structures. The first one is a
functional representation of non nul binary numbers *)
Inductive positive :=
| xH (* 1 *)
| xO (p:positive) (* 2 p *)
| xI (p:positive) (* 2 p +1 *)
Check xI (xI (xO xH)).
(** represents 1 + 2 * (1 + 2 * (2 * 1)) = 11 = Ox1011 *)
Module PosStringMap <: MAP
with Definition key := positive
Definition key := positive.
(** We now want to define a tree structure. *)
Inductive tree :=
| Leaf
| Node (a:string) (l r:tree).
Definition t := tree.
Fixpoint get (t: tree) (p:positive) :=
match t, p with
| Leaf, _ => default
| Node a l r, xH => a
| Node a l r, xO p => get l p
| Node a l r, xI p => get r p
end.
Definition empty : t := Leaf.
Fixpoint set (t:tree) (p:positive) (s:string) :=
match t, p with
| Leaf, xH => Node s Leaf Leaf
| Leaf, xO p => Node default (set Leaf p s) Leaf
| Leaf, xI p => Node default Leaf (set Leaf p s)
| Node a l r, xH => Node s l r
| Node a l r, xO p => Node a (set l p s) r
| Node a l r, xI p => Node a l (set r p s)
end.
Proof.
go.
Qed.
Proof.
Qed.
Proof.
induction k; destruct m; destruct k'; simpl; go;
intros; rewrite IHk; go.
Qed.
End PosStringMap.
Notation "m [ k ]" := (PosStringMap.get m k) (at level 20).
Notation "m +{ k ↦ e }" := (PosStringMap.set m k e) (at level 20).
Notation "{}" := (PosStringMap.empty) (at level 20).
Definition p1 := xH.
Definition p2 := xO xH.
Definition p3 := xI xH.
Definition p4 := xO (xO xH).
Definition p6 := xO (xI xH).
Compute ({} +{p2 ↦ "two" } +{p3 ↦ "three" } +{p6 ↦ "six" } [p6]).
Compute ({} +{p2 ↦ "two" } +{p3 ↦ "three" } +{p6 ↦ "six" } [p4]).
Compute ({} +{p2 ↦ "two" } +{p3 ↦ "three" } +{p6 ↦ "six" } [p3]).
Compute ({} +{p2 ↦ "two" } +{p3 ↦ "three" } +{p6 ↦ "six" } [p2]).
Compute ({} +{p2 ↦ "two" } +{p3 ↦ "three" } +{p6 ↦ "six" } [p1]).
Le 30 janv. 2015 à 21:01, Eric Mullen
<emullen AT cs.washington.edu>
a écrit :
> If you wanted to give a 10 minute demo to show off how cool Coq was, what
> example would you use?
> Specifically, if you were talking to a bunch of undergraduates in Computer
> Science, and you had 10 minutes to convince them that Coq was an awesome
> research tool, what would be your go to example?
> Ideas so far have been:
> * Implementing slow and fast Fibonacci functions, and proving they
> calculate the same thing
> * Proving that the identity function and the Fibonacci function are both
> monotonic
> I'm leaning towards the second due to its simplicity, but I would very much
> appreciate small examples which illustrate how cool it is to write code and
> prove properties about it.
> Thanks much,
> Eric Mullen
  • Re: [Coq-Club] How to show off Coq, David Pichardie, 02/03/2015
