coq-club - Re: [Coq-Club] Well founded relation for computation termination.
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Well founded relation for computation termination.
  • Date: Wed, 4 Feb 2015 10:01:18 +0100
On Wed, 4 Feb 2015 07:24:17 +0100
Julien Forest
<julien.forest AT ensiie.fr>
wrote:
> Hi Mukesh,
> maybe you can define first the Ancestor relation on you tree, the show
> that this relation is well founded and then just write something
> like :
> Function f node map {wf Ancestor node} :=
> | None => None
> | Some parent => if beq_nat node parent then node else find
> parent map end.
> and do a proof very similar to Pierre's proposal.
> Best regards,
> Julien
> On Wed, 4 Feb 2015 09:22:43 +0530
> mukesh tiwari
> <mukeshtiwari.iiitm AT gmail.com>
> wrote:
> > Hi Pierre,
> > Thank you for reply. Sorry for not being clear about problem.
> > On Tue, Feb 3, 2015 at 8:02 PM, Pierre Courtieu
> > <pierre.courtieu AT gmail.com>
> > wrote:
> > > Hi, I found bizarre that you put f as an argument of moveup.
> > The idea is, I have a tree and each node has parent. Root is parent
> > of itself. Now I am looking for path from any given node ( n ) to
> > root. I am storing node as key and its parent as value in map.
> > Fixpoint f node map :=
> > match find node map with
> > | None => None
> > parent map end.
> > This function is not accepted in Coq because Coq is not convinced
> > about termination. If I have well founded relation between node and
> > its parent then it will be convinced. I am looking for how encode
> > this property as well founded relation. I don't know the path length
> > in advance but all I know is, it will go to root and there my
> > computation will terminate.
> > Regards,
> > Mukesh Tiwari
