- From: Jean-Francois Monin <jean-francois.monin AT imag.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Tatic similar to discriminate
- Date: Tue, 10 Feb 2015 14:26:35 +0100
- Mailscanner-null-check: 1424179594.58258@GzNH9faTi2urlF7S98gotA
Note that induction is really needed:
l = x :: l makes sense for circular lists,
as well as n = S n for infinite numbers.
JF
On Tue, Feb 10, 2015 at 10:03:41AM -0300, Saulo Araujo wrote:
> Thanks a lot Pierre!
> On Tue, Feb 10, 2015 at 9:42 AM, Pierre Casteran
> <[1]pierre.casteran AT labri.fr>
> wrote:
> Hi,
> You can prove an auxiliary lemma by induction, using both discriminate
> and injection.
> Using list length leads you to use the fact that no natural number is
> eaual to its successor, which you can prove by the same technique.
> Pierre
> Require Import List.
> Goal forall A (l : list A) (a:A), l <> a::l.
> induction l.
> -discriminate.
> - injection 1.
> intros H0 _ ; now destruct (IHl a).
> Qed.
> Le 10/02/2015 13:31, Saulo Araujo a écrit :
> Hi,
> I am trying to prove a theorem and got stuck. I have the following
> hypothesis
> H0 : l = (c, p) :: l
> which says that a list is equal to the tail of another list. This, I
> believe, is never true. Prooving another simpler theorem I also got
> in
> a
> situation like this and, in that simpler case, I could end the proof
> using the discriminate tactic, but in this case, Coq says:
> Error: No primitive equality found.
> Does anyone know what can I do?
> Thanks in advance,
> Saulo
- [Coq-Club] Tatic similar to discriminate, Saulo Araujo, 02/10/2015
- Re: [Coq-Club] Tatic similar to discriminate, Frédéric Besson, 02/10/2015
- Re: [Coq-Club] Tatic similar to discriminate, Pierre Casteran, 02/10/2015
- Re: [Coq-Club] Tatic similar to discriminate, Saulo Araujo, 02/10/2015
- Re: [Coq-Club] Tatic similar to discriminate, Jean-Francois Monin, 02/10/2015
- Re: [Coq-Club] Tatic similar to discriminate, Cedric Auger, 02/10/2015
- Re: [Coq-Club] Tatic similar to discriminate, Saulo Araujo, 02/13/2015
