Re: [Coq-Club] How to prove that all vectors of 0 length are equal to Vector.nil
- From: Tom Hirschowitz <tom.hirschowitz AT univ-savoie.fr>
- To: Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>, coq-club AT inria.fr
- Cc:
- Subject: Re: [Coq-Club] How to prove that all vectors of 0 length are equal to Vector.nil
- Date: Tue, 10 Feb 2015 17:25:38 +0100
Also stumbled on this a few weeks back.
Nicolas Tabareau showed me this
(** A vector of length [0] is [nil] *)
Definition case0 {A} (P:t A 0 -> Type) (H:P (nil A)) v:P v :=
match v with
|[] => H
|_ => fun devil => False_ind (@IDProp) devil (* subterm !!! *)
end.
from VectorDef.v in theories/Vectors, which easily entails the result.
But which i can't type check, although obviously Coq can!
Would you please be able to explain this trick and why it is (was?)
needed?
Tom
Pierre Boutillier
writes:
> Require Vector.
> Definition Vector_0_is_nil (T : Type) (v : Vector.t T 0) : v = Vector.nil T
> match v with Vector.nil => eq_refl end.
> :-) Yes, destruct is less smart than it should as the term inference is
> able to solve this case … Life’s too short to do all we would like to do!
> Pierre B.
>> On 10 Feb 2015, at 17:01, Soegtrop, Michael
>> <michael.soegtrop AT intel.com>
>> wrote:
>> Dear Coq users,
>> I have difficulties to show the following:
>> Require Import Vector.
>> Lemma Vector_0_is_nil: forall (T : Type) (v : Vector.t T 0), v =
>> Vector.nil T.
>> Since Vector.nil is the only constructor for vectors of length 0, this
>> should be the case, but I can't find a way to prove it. Inversion on v
>> yields nothing and tactics like destruct and induction lead to type
>> checker errors. Also generalizing over arbitrary length with hypothesis
>> n=0 leads to type checker errors.
>> Best regards,
>> Michael
- [Coq-Club] How to prove that all vectors of 0 length are equal to Vector.nil, Soegtrop, Michael, 02/10/2015
- Re: [Coq-Club] How to prove that all vectors of 0 length are equal to Vector.nil, Pierre Boutillier, 02/10/2015
- Re: [Coq-Club] How to prove that all vectors of 0 length are equal to Vector.nil, Tom Hirschowitz, 02/10/2015
- Re: [Coq-Club] How to prove that all vectors of 0 length are equal to Vector.nil, Adam Chlipala, 02/10/2015
- RE: [Coq-Club] How to prove that all vectors of 0 length are equal to Vector.nil, Soegtrop, Michael, 02/11/2015
