coq-club - Re: [Coq-Club] an awkward question about "case" tactic
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] an awkward question about "case" tactic
  • Date: Tue, 10 Feb 2015 11:37:43 -0500
On 02/10/2015 11:33 AM, Matej Kosik wrote:
Hello,
If my context is:
a : nat
and my goal is:
(fun c : nat => c + a + a = 42) a
then when I use the
case a
tactic, the original goal is replaced with the following two subgoals:
0 + a + a = 42
forall n : nat, S n + a + a = 42
This effect is plausible;
the usefulness of it is documented (e.g. in Coq'Art);
but I am not able to explain why "case a" must have in this case this effect
and not some other effect.
For example, why doesn't Coq generated the following subgoals instead:
0 + 0 + 0 = 42
forall n : nat, S n + S n + S n = 42
Why is the third occurrence of the free variable "a" in the original goal
treated in a different way than its first and the second occurrences?
I don't know about the "why" - but you can get around it by using [pattern a] before [case a].
-- Jonathan
