coq-club - Re: [Coq-Club] Incorrect elimination (defining function within proof)
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Incorrect elimination (defining function within proof)
  • Date: Thu, 12 Feb 2015 20:10:06 -0600
Thanks Daniel. You are right, the axiom of choice proves this fairly easily:
Variable state : Set.
Definition transition := state -> state -> Prop.
Variable T : transition.
Definition trace := nat -> state.
Definition total : Prop :=
forall s, exists s', T s s'.
Require Import ClassicalChoice.
Theorem total_has_trace :
total -> forall s, exists P, P 0 = s /\ forall n, T (P n) (P (S n)).
intros.
apply choice in H as [f Hf].
exists (fix p n := match n with
| 0 => s
| S n' => f (p n')
end).
auto.
Qed.
On Thu, Feb 12, 2015 at 8:00 PM, Daniel Schepler
<dschepler AT gmail.com>
wrote:
> On Thu, Feb 12, 2015 at 5:16 PM, Andrew Gacek
> <andrew.gacek AT gmail.com>
> wrote:
>> I'm trying to prove that a total transition system has an infinite
>> trace starting from any state. The problem is that I need to provide a
>> witness for the trace which involves defining a fixed point. This
>> fixed point needs to destruct an existential, but that results in an
>> error about incorrect elimination. I thought there might be a way
>> around this since I'm still doing everything within the context of a
>> proof. Or perhaps what I'm trying to prove isn't intuitionistically
>> true?
>> intros.
>> | 0 => s
>> | S n' => match H (p n') with
>> | ex_intro s' Hs' => s'
>> end
>> end).
>> The last line here results in:
>> Error:
>> Incorrect elimination of "H (p n'0)" in the inductive type "ex":
>> the return type has sort "Set" while it should be "Prop".
>> Elimination of an inductive object of sort Prop
>> is not allowed on a predicate in sort Set
>> because proofs can be eliminated only to build proofs.
>> Please let me know if you have any ideas about how to go about proving
>> this.
> This is fairly close to the axiom of (countable) dependent choice, which
> isn't even provable assuming excluded middle. You might look into using the
> axiom of choice (Require Import Choice.) To prove your statement, the major
> stepping stone would be to use the axiom of choice to prove (exists totalT :
> state -> state, forall s, T s (totalT s)). The first step of
> total_has_trace would then be to destruct the exists statement, and then
> construct a fixpoint function similarly to what you did above.
> Daniel Schepler
