coq-club - Re: [Coq-Club] differentiate hyps from section vars
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] differentiate hyps from section vars
  • Date: Mon, 16 Feb 2015 12:14:05 -0500
On 02/16/2015 05:26 AM, Pierre-Marie Pédrot wrote:
On 16/02/2015 10:57, Pierre-Marie Pédrot wrote:
I am fairly sure that a ten-line plugin is enough to define the tactic
you're longing for.
There you go.
https://github.com/ppedrot/issection-tactic/tree/master
PMP
Thanks, PMP!
OK - so this tactic was so easy to write in ML because there already was an "is_section_variable" function in ML... sigh...
I continue to be embarrassed by my lack of knowledge of how to write ML plugins for tactics.
But, is anyone going to create suitable documentation/tutorials on tactic plugin development to help? For example, this plugin uses "match kind c with", while the closely related "is_var" tactic uses "match kind_of_term x with" - why the difference?
Beyond the lack of doc, my further reluctance is due to: whatever tactic I write with Ltac, as kludgey as it may be, it isn't going to cause problems for Coq after it executes. Although I'm not sure about it, it seems to me that the same degree of safety isn't the case with ML tactic plugins. Also, anything written in Ltac is insulated from internal changes in Coq (at least up to behavior changes in builtin Ltac tactics).
-- Jonathan
