coq-club - Re: [Coq-Club] a simple question about "sigT".
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] a simple question about "sigT".
  • Date: Wed, 18 Feb 2015 12:15:37 -0500
On 02/18/2015 12:00 PM, Matej Kosik wrote:
Hello there,
What is "sig", and how to construct values of "sig" seems clear.
I am trying to wrap my head around "sigT".
https://coq.inria.fr/library/Coq.Init.Specif.html#sigT
This seems to be simple enough example term:
{n : nat & {m : nat | n < m}}
Coq says that it has type Set.
I am trying to figure out:
1. what that set represents
It is the Set of triples (actually a pair nested in a pair) of the nat n, the nat m, and a proof that n < m. It is a Set instead of a Prop because it is informative about n and m - each instance can be informatively deconstructed to get at n and m, unlike sigs (sigs can only be deconstructed to produce other uninformative Props).
2. how can I construct elements of that Set.
You would use the existT and exist constructors. An example instance is:
(existT (fun n : nat => {m : nat & n < m}) 1 (exist (fun m : nat => 1 < m) 2 (le_n 2)))
which Coq can infer from this much easier to read version:
(existT _ 1 (exist _ 2 (le_n 2)))
-- Jonathan
