- From: Jean-Francois Monin <jean-francois.monin AT imag.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] library Coq.Numbers.Natural.Abstract.NPow : how to use it.
- Date: Thu, 19 Feb 2015 18:21:36 +0100
The statement of Nat.log2_pow2 is very strange:
why on the hell do they add the precondition add 0 <= nat ???
My 2 cts,
JF
On Thu, Feb 19, 2015 at 11:08:05AM -0500, Abhishek Anand wrote:
> The official library-docs don't tell the full story :)
> Coq provides much more powerful ways to search for content.
> You might want to learn about commands lke SearchAbout, SearchPattern,
> SearchRewrite, e.t.c :
> [1]https://coq.inria.fr/distrib/current/refman/command-index.html
> The commands I used to find the lemma are there in the email itself.
> If you open CoqIDE and type the following 2 lines, Nat.log2_pow2 will
> show
> up in the RHS bottom sub-window
> Require Export Coq.Numbers.Natural.Peano.NPeano.
> SearchAbout (log2 (2^?x)).
> Here is a screenshot:
> [2]https://dl.dropboxusercontent.com/u/79447152/CoqIDESearch.png
> Regards,
> -- Abhishek
> [3]http://www.cs.cornell.edu/~aa755/
> On Thu, Feb 19, 2015 at 10:42 AM, Michel Levy
> <[4]michel.levy1948 AT gmail.com>
> wrote:
> On 19/02/2015 16:12, Abhishek Anand wrote:
> It is already there in the standard library:
> Nat.log2_pow2: forall a : nat, 0 <= a -> log2 (2 ^ a) = a
> -- Abhishek
> [5]http://www.cs.cornell.edu/~aa755/
> Thank you really much for your answer.
> But how did you find it ? I was looking at the "official doc" in
> [6]https://coq.inria.fr/distrib/current/stdlib/Coq.Numbers.Natural.Peano.NPeano.html
> and I don't find Nat.log2_pow2 on this page or in the web index of the
> standard library.
> Sincerely yours.
- [Coq-Club] library Coq.Numbers.Natural.Abstract.NPow : how to use it., michel levy, 02/19/2015
- Re: [Coq-Club] library Coq.Numbers.Natural.Abstract.NPow : how to use it., Abhishek Anand, 02/19/2015
- Re: [Coq-Club] library Coq.Numbers.Natural.Abstract.NPow : how to use it., Michel Levy, 02/19/2015
- Re: [Coq-Club] library Coq.Numbers.Natural.Abstract.NPow : how to use it., Jean-Francois Monin, 02/19/2015
- Re: [Coq-Club] library Coq.Numbers.Natural.Abstract.NPow : how to use it., Robbert Krebbers, 02/19/2015
