- From: Pierre-Marie Pédrot <pierre-marie.pedrot AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] how to (almost) do Ltac try/raise in 8.5
- Date: Fri, 27 Feb 2015 16:12:13 +0100
On 27/02/2015 16:06, Jonathan Leivent wrote:
> Or, perhaps you are suggesting that Ltac is better off without any
> exception-like mechanism?
I think I'm suggesting Ltac is better off without any Ltac.
More seriously, your hack is legitimate, but I just wanted to warn you
not to rely too much on the current semantics of tactics-in-terms. The
only use case where the semantics is fully specified is when:
1. The tactic is totally solving the current hole (so always writing
$(solve [tac])$ is a good idea).
2. The tactic does not mess with the global evars of the current proof
state (do not try to do $(instantiate (i := foobar))$)
3. The tactic do not rely on global side-effects (that currently
includes the abstract tactical).
If you comply with these three conditions, you should be safe regarding
the potential evolutions of the implementation. Still, be careful.
PMP
signature.asc
Description: OpenPGP digital signature
- [Coq-Club] how to (almost) do Ltac try/raise in 8.5, Jonathan Leivent, 02/27/2015
- Re: [Coq-Club] how to (almost) do Ltac try/raise in 8.5, Pierre-Marie Pédrot, 02/27/2015
- Re: [Coq-Club] how to (almost) do Ltac try/raise in 8.5, Enrico Tassi, 02/27/2015
- Re: [Coq-Club] how to (almost) do Ltac try/raise in 8.5, Jonathan Leivent, 02/27/2015
