coq-club - [Coq-Club] How to solve trivial evars automatically, so that they don't get shelved?
  • From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: [Coq-Club] How to solve trivial evars automatically, so that they don't get shelved?
  • Date: Fri, 27 Feb 2015 17:27:16 +0000
  • Accept-language: de-DE, en-US
Dear Coq users,
sometimes when I run eauto, I end up with a few shelved evars, which are
trivial to solve, e.g. just a nat. This happens e.g. in the following
simplified use case:
Parameter f : nat -> nat.
Parameter Lemma1 : forall m n : nat, f m <> 0 -> f n <> 0.
Lemma Test1: (forall m : nat, f (S m) <> 0) -> (forall n : nat, f n
<> 0).
Proof.
intros H n.
eauto using Lemma1.
At the end of the proof I have to do
Unshelve.
exact 0.
This is a bit inconvenient because Unshelve is a vernacular command, not
Ltac, so it cannot be embedded in a scripts and automated.
The only automated method I came up with is to initially create an artificial
extra goal and when solving this goal search for evars and instantiate them,
but this is bit complicated.
Is there some elegant way to say "if you need a nat, take 0"? I tried
"Declare Implicit Tactic assumption" but this doesn't work, although a nat is
among the Hypothesis.
Thanks & best regards,
Michael
