- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Memoizing coqc?
- Date: Tue, 24 Mar 2015 16:31:36 -0400
I don't think -inputstate and -outputstate work (except when building the standard library?) in Coq 8.4, and they have been removed entirely in Coq 8.5.
-Jason
On Tue, Mar 24, 2015 at 6:11 AM, Jacek Chrząszcz <chrzaszcz AT mimuw.edu.pl> wrote:
There are -inputstate and -outputstate options to coqtop, they could
be useful...
Bests
Jacek
2015-03-24 0:36 GMT+01:00 Jason Gross <jasongross9 AT gmail.com>:
> Hi,
> How hard would it be to write a Coq wrapper that performed memoization?
> More precisely, I want a daemon that I can feed multiple file names over a
> period of time, and if a given file shares the first 90% of its lines with a
> previously given file, only the last 10% of the lines in the second file
> should need to be run.
> I've thought about writing a python wrapper around `coqtop -emacs` and using
> `BackTo` to implement this, but I am curious if (a) such a tool already
> exists, or (b), it would be easy to write an alternative ocaml coq toplevel
> that did this memorization?
> (The main use case for this would be my bug-minimizer, and it would also be
> useful on a group of files that spend a lot of time on initial imports, and
> all import the same libraries.)
> Thanks,
> Jason
- [Coq-Club] Memoizing coqc?, Jason Gross, 03/24/2015
- Re: [Coq-Club] Memoizing coqc?, Jacek Chrząszcz, 03/24/2015
- Re: [Coq-Club] Memoizing coqc?, Jason Gross, 03/24/2015
