- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] how to prove false
- Date: Wed, 25 Mar 2015 21:17:40 +0100
But it now is, in the v8.5 branch of Coq.
Le mercredi 25 mars 2015, Laurent Théry <Laurent.Thery AT inria.fr> a écrit :
Unfortunately you increase your trusted base when using vm_compute.
In this case, you hit one of the limitation of the byte-code machinery. It is just a pity
it was not checked by the command.
On 03/25/2015 06:30 PM, Jonathan Leivent wrote:
On 03/25/2015 12:55 PM, Laurent Théry wrote:
OK - I'm panicking a bit less...
Were you using an inductive type with more than 255 constructors? ;-)
I didn't say what "a bit less" was relative to ;-)
Still, I was under the ever-so-slightly? mistaken impression that things are either outside (and hence checked by) the kernel, or, if in the kernel, are simple enough and scrutinized enough not to encounter such issues.
-- Jonathan
- [Coq-Club] how to prove false, Stefan Ciobaca, 03/25/2015
- Re: [Coq-Club] how to prove false, Jonathan Leivent, 03/25/2015
- Re: [Coq-Club] how to prove false, Jacques-Henri Jourdan, 03/25/2015
- Re: [Coq-Club] how to prove false, Laurent Théry, 03/25/2015
- Re: [Coq-Club] how to prove false, Matthieu Sozeau, 03/25/2015
