- From: Robbert Krebbers <mailinglists AT robbertkrebbers.nl>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Error: Tactic failure: not a valid ring equation.
- Date: Fri, 27 Mar 2015 14:21:35 +0100
The problem is that the ring tactic treats "2" as just an arbitrary constant. There are two ways around it:
* Define "2" in an alternative way:
Notation "2" := (1 + 1)%C : C_scope.
* Use the "constant" modifier of the "Add Ring" command, see
https://coq.inria.fr/doc/Reference-Manual027.html#hevea_command357
On 03/27/2015 02:14 PM, Matej Kosik wrote:
Hello,
I have recently (again) stumbled upon the "Add Ring ..." command and decided
to make some experiments with it
(mainly to see if I can define a custom ring from scratch and make sure that
the ring tactic works for the custom ring as successfully as in the other
usual cases).
I have picked to define Gaussian integers.
(the attached file contains the complete experiment)
I had a partial success.
Some of the goals can be solved automatically:
Goal forall x y, ((x+y)*(x+y)*(x-x) = 0)%C.
Proof.
intros.
ring.
Qed.
However, there are cases when ring tactic fails, e.g.:
Goal forall x y, ((x+y)*(x+y) = x*x + 2*x*y + y*y)%C.
Proof.
intros.
ring.
There I get
On the other hand, the same goal on the Z-ring is handled by ring-tactic just
fine:
Goal forall x y, ((x+y)*(x+y) = x*x + 2*x*y + y*y)%Z.
Proof.
intros.
ring.
Qed.
I would like to ask two (related) questions:
How come that "((x+y)*(x+y) = x*x + 2*x*y + y*y)%C" is not a valid ring
equation?
What exactly is meant by "ring equation"?
Thank you very much for any help or hints.
- [Coq-Club] Error: Tactic failure: not a valid ring equation., Matej Kosik, 03/27/2015
- Re: [Coq-Club] Error: Tactic failure: not a valid ring equation., Robbert Krebbers, 03/27/2015
