coq-club - Re: [Coq-Club] Program Fixpoint and simpl
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Program Fixpoint and simpl
  • Date: Sun, 29 Mar 2015 18:31:54 -0400
On 03/29/2015 05:06 PM, Zoe Paraskevopoulou wrote:
Hello everyone,
I am trying to define a recursive function using Program Fixpoint. In
particular, I am providing a measure and I am proving that this measure
decreases in every recursive call.
However, when I try to prove a lemma involving this function I am unable to
use simpl in order to prove the inductive cases and when I try to manually
unfold the definition I am getting a very big term.
A simplified and self contained example of the problem I am running into can be
found here: https://gist.github.com/zoep/6167e14ed0ebe0887a03
<https://gist.github.com/zoep/6167e14ed0ebe0887a03> (the problematic lemma is
at the end of the file)
Any help would be greatly appreciated.
Cheers,
Zoe
I think this is a standard issue with Program - it often produces very large proof terms that are very hard to deal with when unfolded. That's just the price of using its automation instead of going it alone.
My way of dealing with functions that have large proof terms is to make sure I don't need to unfold them - that their dependent types are sufficiently expressive such that the functions themselves can be left opaque. Note that this technique has its own issues - but if it can be mastered, I think it has other benefits. After all, unfolding a function is an inherently unmodular thing to do, as it will make any resulting proofs very dependent on the current implementation of that function.
Assuming you want to stick with what you already have, one thing you might want to try is to define a second already reduced version of infer_sort as:
Definition infer_sort':= Eval compute in infer_sort.
and see if the proof term of infer_sort' can be dealt with more easily when unfolded. Another thing to try is to use refine instead of Program - you'll still get some ability to handle obligations later in proof mode, and you'll end up with a less complex proof term (assuming you can handle the proof obligations, and that they don't add too much heft). Hmmm - I see you use omega. That in itself can lead to pretty large proof terms. It might be best to use abstract omega instead, making sure you export the resulting abstractions so that they aren't just inlined.
-- Jonathan
