coq-club - [Coq-Club] Coq plugins depending on external libraries
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: [Coq-Club] Coq plugins depending on external libraries
  • Date: Wed, 1 Apr 2015 16:43:15 +0200 (CEST)
Hello,
I have a problem writing a coq plugin that depends on external OCaml libraries. This is the logical continuation of a previous thread called "[Coq-Club] coq_makefile and ocamlfind". Suppose I have a plugin MyPlugin that loads an ML module MyModule that depends on external libraries Lib1, Lib2, Lib3. The file MyPlugin.v looks like this:
    Declare ML Module "lib1".
    Declare ML Module "lib2".
    Declare ML Module "lib3".
    Declare ML Module "myModule".
I can successfully compile the plugin I give the proper search paths to ocamlc and coqc:
    ocamlc -I path/to/lib1 -I path/to/lib2 -I path/to/lib3 myModule.ml
    coqc -I path/to/lib1 -I path/to/lib2 -I path/to/lib3 MyPlugin.v
The problem is that I cannot load my plugin in Coq without explicitly giving the paths to the external libraries, every time I want to use it, either when calling coq:
or by using the Add Path commands in coq:
    Add ML Path "path/to/lib1".
    Add ML Path "path/to/lib2".
    Add ML Path "path/to/lib3".
Only then can I load the shiny new module:
    Require MyPlugin.
As you can guess, this is very cumbersome. Has anyone faced this problem before? Is there any way to solve it in a portable way (by not hardcoding the paths in MyPlugin.v)? I tried looking for a way to package the libraries with the plugin but so far I have not been successful.
Thanks,
Ali Assaf
