coq-club - Re: [Coq-Club] How can I get [setoid_rewrite] to consider things weaker than [pointwise_relation]?
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] How can I get [setoid_rewrite] to consider things weaker than [pointwise_relation]?
  • Date: Fri, 10 Apr 2015 10:16:33 +0200
Hi,
  this is indeed desirable and doable but cannot be performed with the current generalized rewriting
machinery. Technically, one needs to change the rule Lambda on p12 of http://jfr.unibo.it/article/view/1574/1077
to produce a ==> relation instead of a pointwise equivalence and do multiple rewrites
at the same time recursively, i.e rewrite the body (f x /\ H) under the context (x x' : A) (Hx : ?R x x')
in general, logical-relation style. I'd be happy to guide anyone who wants to implement this :)
Best,
-- Matthieu
2015-04-08 20:32 GMT+02:00 Jason Gross <jasongross9 AT gmail.com>:
Hi,
What instances to I need to add to the environment to make this example work?
Require Import Coq.Setoids.Setoid Coq.Lists.List Coq.Program.Basics Coq.Classes.Morphisms.
Global Instance fold_right_flip_impl {A}
: Proper
    (pointwise_relation A (flip impl ==> flip impl) ==> flip impl ==> eq ==> flip impl)
    (@fold_right _ A).
Proof.
  intros ??????? ls ?; subst.
  induction ls; simpl; trivial.
  unfold flip, impl, pointwise_relation, respectful in *.
  eauto.
Qed.
Goal forall A f g ls, (forall x : A, f x <-> g x) -> fold_right (fun x H => f x /\ H) True ls.
Proof.
  intros A f g ls H.
  Typeclasses eauto := debug.
  try timeout 2 setoid_rewrite H.
It seems that it gets stuck on trying to find an instance for
  (Proper
   (pointwise_relation A (pointwise_relation Prop iff) ==>
    ?92 ==> ?91 ==> flip impl) (fold_right (B:=A)))
and rightly fails.  But this transformation is possible, as the following tactic shows:
  cut (fold_right (fun x H => g x /\ H) True ls);
    [ induction ls; simpl in *; trivial; [];
      intros [H0' H1']; split; try apply H; eauto
Show how to I get [setoid_rewrite] to consider [pointwise_relation A (R ==> iff)] for an arbitrary [Reflexive] [R], rather than just for [R] being [eq]?
Thanks,
Jason
