coq-club - Re: [Coq-Club] trouble installing from source on debian
  • From: Matej Kosik <5764c029b688c1c0d24a2e97cd764f AT gmail.com>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] trouble installing from source on debian
  • Date: Sun, 12 Apr 2015 21:29:38 +0100
On 11/04/15 22:39, Andrew Harris wrote:
> Hello, I'm trying to install coq8.5beta from source. I can do the
> ./configure and make world steps OK. But when I get to the make install
> step, I'm getting an error during the install:
Hi,
I am using Debian stable.
I had problems *building* Coq before.
After some experiments, I found that this sequence of commands works for me
reliably:
git pull # if necessary
make archclean && ./configure -annotate -prefix /usr/local && make clean &&
make world && make install
The devil is hidden in "make archclean".
I do not think that it is supposed to be a necessary step, but if I omitted
it, rebuilding of Coq was failing.
> install -d "/usr/local/lib/coq"/plugins/micromega
> install plugins/micromega/csdpcert "/usr/local/lib/coq"/plugins/micromega
> rm -f "/usr/local/lib/coq"/revision
> install -m 644 revision "/usr/local/lib/coq"
> install: cannot stat `revision': No such file or directory
> make[1]: [install-library] Error 1 (ignored)
> install -d "/usr/local/share/man"/man1
> install: cannot create directory `/usr/local/share/man/man1': File exists
> make[1]: *** [install-coq-manpages] Error 1
> make[1]: Leaving directory `/home/andrewha/Downloads/coq-8.5beta1'
> make: *** [submake] Error 2
> Any help would be appreciated.
> -andrew
