- From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: [Coq-Club] Error using "rewrite with" in Coq 8.5beta1 when names clash
- Date: Wed, 22 Apr 2015 10:39:12 +0000
- Accept-language: de-DE, en-US
Dear Coq users,
I sometimes get an error using “rewrite with” when local names and the names used for bound variables in the rewriting lemma clash. Below is an example. Rewrite says that I can’t use the names from the lemma, but have to use some extended names. I don’t see a way to know these different names in automation. Also in other situations the name clash doesn’t seem to be a problem. Is this a bug or do I miss something?
Best regards,
Michael
(* ===== Example for rewrite with issue ===== *)
Require Import List. Import ListNotations.
Lemma app_cons: forall {T : Type} (x : T) (l : list T), x::l = [x]++l. Proof. reflexivity. Qed.
Example ExNotOk: forall {T : Type} (x : T) (l : list T), x::l = [x]++l. Proof. intros T x l. (* The below rewrite with fails with Error: No such bound variable x (possible names are: x0 and l0) *) Fail rewrite app_cons with (x:=x) (l:=l).
(* The rewrite with renamed variables works *) rewrite app_cons with (x0:=x) (l0:=l). reflexivity. Qed.
Example ExOk: forall (l m n : list nat), l ++ m ++ n = (l ++ m) ++ n. Proof. intros l m n. (* But this rewrite works, although I use the same names locally as in the definition of the rewrite lemma *) rewrite app_assoc with (l:=l) (m:=m) (n:=n). reflexivity. Qed.
- [Coq-Club] Error using "rewrite with" in Coq 8.5beta1 when names clash, Soegtrop, Michael, 04/22/2015
