- From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: RE: [Coq-Club] Coq 8.5 beta 2
- Date: Thu, 23 Apr 2015 13:52:39 +0000
- Accept-language: de-DE, en-US
Dear Coq Team,
many thanks for your efforts on further improving Coq!
You might want to mention in the change log the changes done with bug-fix
3199 (cost for extern hints is actually taken into account). I have some
files where this changed the eauto proof search time from a few seconds to
infinite because some hint which can be repeated endlessly ended up having
lower cost than a hint solving the goal. It is easy to fix the hint costs,
but you have to know it.
Best regards,
Michael
-----Original Message-----
matthieu.sozeau AT gmail.com
[mailto:matthieu.sozeau AT gmail.com]
On Behalf Of Matthieu Sozeau
Sent: Thursday, April 23, 2015 3:37 PM
To:
Subject: [Coq-Club] Coq 8.5 beta 2
Dear Coq-Clubers,
The Coq development team is pleased to announce the release of the second
beta version of Coq 8.5 available at:
http://coq.inria.fr/coq-85
This new beta version includes many bug fixes with respect to the first
beta version released in January, and a few incompatible changes, see the
following file for more information:
https://coq.inria.fr/distrib/V8.5beta2/CHANGES
Source, Windows and OS X packages are available.
We recall the new available features of version 8.5:
- asynchronous edition of documents under CoqIDE to keep working on a
proof while Coq checks the other proofs in the background (by Enrico
Tassi);
- universe polymorphism making it possible to reuse the same
definitions at various universe levels (by Matthieu Sozeau);
- primitive projections improving space and time efficiency of
records, and adding eta-conversion for records (by Matthieu Sozeau);
- extensions of the new proof engine featuring dependent subgoals
management, fully backtracking tactics, as well as tactics which can
consider multiple goals together (by Arnaud Spiwack);
- a new reduction procedure called native_compute to evaluate terms
using the OCaml native compiler, for proofs with large computational
steps (by Maxime Dénès).
The main other changes are:
- a new fast compilation chain that skips checking of proofs (producing
.vio files);
- a new construct $(..)$ to call tactics from term definitions;
- a more restrictive guard condition to recover compatibility with axioms
like propositional extensionality and (some consequences of) univalence;
- a new option -type-in-type to collapse the universe hierarchy (makes
the logic inconsistent but useful for exploration);
- a better-behaved alternative to simpl, called cbn;
- various improvements to the tactic language, like a new introduction
pattern [= x1 ... xn] which applies injection on the fly (inspired
by SSReflect); new constructs uconstr:c and type_term c to build
untyped terms in Ltac;
- significant improvements of general efficiency.
See http://coq.inria.fr/ for more details, and the CHANGES file in the
distribution for a comprehensive list.
The Coq development team wishes to acknowledge the many people who made Coq
8.5 possible: Pierre Boutillier, Pierre Courtieu, Maxime Dénès, Hugo
Herbelin, Pierre Letouzey, Pierre-Marie Pédrot, Yann Régis-Gianas, Matthieu
Sozeau, Arnaud Spiwack, Enrico Tassi with contributions also from Bruno
Barras, Yves Bertot, Frédéric Besson, Xavier Clerc, Pierre Corbineau,
Jean-Christophe Filliâtre, Julien Forest, Sébastien Hinderer, Assia Mahboubi,
Guillaume Melquiond, Jean-Marc Notin, François Ripault, Carst Tankink as well
as many external contributors.
The Coq Development Team
- [Coq-Club] Coq 8.5 beta 2, Matthieu Sozeau, 04/23/2015
- RE: [Coq-Club] Coq 8.5 beta 2, Soegtrop, Michael, 04/23/2015
