coq-club - Re: [Coq-Club] a question about a passage in the Reference Manual about inductive definitions
  • From: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] a question about a passage in the Reference Manual about inductive definitions
  • Date: Mon, 27 Apr 2015 13:45:25 +0200
On 27/04/2015 12:44, Matej Kosik wrote:
I can work with those values normally.
E.g.:
Definition is_empty (A:Type) (l : list1 A) :=
match l with
| nil1 _ => true
| cons1 _ _ _ => false
end.
Compute is_empty nat (nil1 nat).
Compute is_empty nat (cons1 nat 5 (nil1 nat)).
I am curious, why is "list1" as defined above inferior to "list" as it
appears in the standard library?
That is because you chose a function that is way too simple. Try instead to define a function of type (list1 A -> option A). You can no longer do a simple match, you have to use type-dependent pattern-matching.
Definition head {A} (l : list1 A) : option A :=
match l in list1 H return option H with
| nil1 _ => None
| cons1 _ h _ => Some h
end.
Even worse, try to define the map function. The f function can no longer be applied to the head element of your list because it does not have the correct type, a priori. This forces you to write the following code.
Fixpoint map {A B} (f : A -> B) (l : list1 A) : list1 B :=
match l in list1 H return (H -> B) -> list1 B with
| nil1 _ => fun _ => nil1 _
| cons1 _ h t => fun f => cons1 _ (f h) (map f t)
end f.
Best regards,
Guillaume
