- From: Pierre Courtieu <pierre.courtieu AT gmail.com>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] forall implication
- Date: Mon, 27 Apr 2015 16:51:55 +0200
If I understand well you want to prove:
x : A
Hi : P x
forall y, P y
which is false.
Maybe you should try to prove something else :)
Best regards,
P.
2015-04-27 16:17 GMT+02:00 richard dapoigny
<richard.dapoigny AT univ-savoie.fr>:
> Le 27/04/2015 15:57, Pierre Courtieu a écrit :
>> Hi,
>> This is no true and therefore not provable.
>> But if you add parenthesis over the first quantified part then it is a
>> different property (and probably the on one you meant?) that is
>> provable by "intro h; assumption."
>> (forall x, (* some complex function depending on x*)) -> forall y, (*
>> the same complex function depending on y*)
>> For examepl:
>> Variable A:Type.
>> Variable P: Type -> Prop.
>> Goal (forall x, (P x)) -> (forall y, P y).
>> Proof.
>> intro h.
>> assumption.
>> Best regards,
>> Pierre
> Thanks for the prompt answer!
> Yes I would like to have the goal you suggest but the problem is that the
> left part is generated by applying generalize x Hi (wher Hi is another
> hypothesis) and therefore I cannot obtain the whole expression due to a lack
> of parentheses
>> 2015-04-27 15:42 GMT+02:00 richard dapoigny
>>> Hi all,
>>> I try to demonstrate a goal having the form:
>>> forall x, (* some complex function depending on x*) -> forall y, (* the
>>> same
>>> Is there a simple way to do it?
>>> Thanks in advance,
>>> Richard
- [Coq-Club] Last Call: The Coq workshop, deadline April 30th, 2015, bertot, 04/21/2015
- [Coq-Club] forall implication, richard dapoigny, 04/27/2015
- Re: [Coq-Club] forall implication, Pierre Courtieu, 04/27/2015
- Re: [Coq-Club] forall implication, richard dapoigny, 04/27/2015
- RE: [Coq-Club] forall implication, Soegtrop, Michael, 04/27/2015
- Re: [Coq-Club] forall implication, Richard Dapoigny, 04/27/2015
